Results 1 to 8 of 8
Thread: Hole in mid question??
10-02-2021, 11:24 AM #1Member
- Jul 2009
- Maine
- 94
- 20
- 27
- 19
10-02-2021, 11:50 AM #26000 RPM
- Nov 2006
- 1,495
- 13
- 129
- 70
- 626
- 35 Post(s)
Hole Purpose
10-02-2021, 12:13 PM #3Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
Thats just the factory exhaust relief hole that connected via rubber port to stock fishing motor cowls,not fittable to hi-po cowls,won't hurt anything,Chris
10-02-2021, 12:22 PM #4Member
- Jul 2009
- Maine
- 94
- 20
- 27
- 19
10-02-2021, 12:25 PM #5Member
- Jul 2009
- Maine
- 94
- 20
- 27
- 19
Rich E.
17' Action Marine/2.5 Pro Max 200
"Badges.........We don't need no stinkin' badges........"
10-02-2021, 12:47 PM #6Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
No problem,get a rubber freeze plug to block it,Chris
Old_Skool thanked for this postphillnjack liked this post
10-11-2021, 11:24 AM #7
No, alien cowl does not cover up that hole. If you put a skirt on your alien then it would cover the hole but blow some exhaust all around the skirt. Like Chris said, if it bothers you, plug it. It was only used on the bucket style cowls with 2 piece pans.
And, some people cut their 260 skirts to fit that hose, but I see you aren't running a cowl skirt.
**If you end up pulling that EGT setup this winter let me know, I'll buy it from you**
10-13-2021, 06:21 PM #8Member
- Jul 2009
- Maine
- 94
- 20
- 27
- 19
- I'll let you know when I pull the EGT..... I'll give you a good deal on it. Frank Molè is picking the boat up next week in Missouri and dragging it up to me in Maine. I'm pretty psyched as this will be my first performance boat ��
Rich E.
Blog this Post
Rich E.
CLE question, 2 hole/ 4 hole
By Ajskennels in forum Technical DiscussionReplies: 14Last Post: 10-20-2017, 10:05 AM -
Mercury Tech: Optmax pee hole question
By skatermike24 in forum Technical DiscussionReplies: 1Last Post: 06-14-2015, 08:42 PM -
Vent hole question
By vnemous in forum Technical DiscussionReplies: 3Last Post: 05-31-2009, 04:00 PM -
Omc question Hole in piston
By steamengine6 in forum Technical DiscussionReplies: 18Last Post: 03-26-2009, 11:04 PM -
Exh Relief Hole Question
By SRP71 in forum Props, Setup, and RiggingReplies: 5Last Post: 04-10-2005, 01:25 AM
