Results 1 to 15 of 18
    Jul 2005
    South Brunswick/ Seaside Park, NJ
    Mercury 2.5 245HP powerhead
    Mercury 2.5 powerhead. Complete drop on. I bought this as a fresh rebuild. It has never been fired. Piston tops are clean and shiny. By the markings on the block, it was most likely done .020 over. Has lightweight flywheel. Located in NJ
    $4,500.00
ID:	493671Click image for larger version.
ID:	493672Click image for larger version.
ID:	493673Click image for larger version.
ID:	493674Click image for larger version.
ID:	493675Click image for larger version.
ID:	493676Click image for larger version.
  2. Likes pkstv, sicknick12 liked this post
    Aug 2006
    GA
    Nice & Clean
    Jul 2002
    FT WORTH, TEXAS
    must be steel steel sleeves
  5. Likes Dave Strong liked this post
    Jul 2005
ID:	494597Click image for larger version.
ID:	494598Click image for larger version.
ID:	494599Click image for larger version.
    Pulled the heads. All holes appear to be steel based on the cross hatching in the cylinders. All holes are 20 over. Pistons are all Promarine based on the part numbers. Block is a clean freshwater block based on the water passages. The heads were also decked based on the hatching on them as well. Will need head gaskets unless I can track down a replacement set.
    Mar 2004
    Brooklyn Park, MN
    Looks like a nikasil. What do the bores measure? GLWS, these are great motors and are very strong.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    Sep 2006
    Is this a big bearing or small bearing powerhead?
    Apr 2020
    South Carolina
    Quote Originally Posted by Air It Out View Post
    My guess would be small. What are guys doing for steel sleeve motors to make them work well from a cooling perspective if you are runing a 1 piece adapter plate?
    Mar 2004
    Brooklyn Park, MN
    Small holes out the adapter plate and keep it warm and regulate the water using poppet dump. And more clearance on the piston to cylinder.
    http://www.us1.cc/racingcoolingsystem.html
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  11. Likes scott reierson liked this post
    WI
    Small bearing unless it was modified for a big bearing & the crank was sleeved or changed. That has got to be a plated .020 over motor.....those sleeves do not like like cast iron liners to me...?
    I have a boat or two.... that I never get to drive
  13. Likes rjdubiel liked this post
    Apr 2020
    South Carolina
    You mean by running a larger ring gap?
    Mar 2004
    Brooklyn Park, MN
    Ring gap is based of bore size. All depends on Pistons too. Forged Pistons need to add .003 to the piston to cylinder clearance. The piston will heat and swell faster than the steel sleeve so need the extra clearance to not scuff
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  16. #12
    Mar 2004
    Brooklyn Park, MN
    Low rpm this info is not needed. 7 to 8k plus do some reading for steel bore with forged Pistons
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    Mar 2004
    Brooklyn Park, MN
    Back to this for sale post. Has the seller replied to anyone?
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  18. #14
    Jul 2005
    I replied to all my PM's.
    Like I said in the first and second post, I did not build the motor nor have someone build it for me. I bought it just as you see it, so I am not sure on the specs as to the bearing size. all 6 sleeves are steel.
  19. #15
    Jan 2020
    Pinole, Ca
    Interested, how long would you be willing to hold it if you got a down payment? I live in Cali and have family in NJ...not sure when I would make it out that way next.
  1. Need a top cowl pin for my Mercury 2.5 245hp
    By Leebone46 in forum Parts Wanted
    Last Post: 06-02-2017, 01:20 PM
  2. 91 mercury 2.5L (carb) 245hp
    By Ale6894 in forum Technical Discussion
    Last Post: 10-29-2016, 04:34 PM
  3. 1993 Mercury 2.4 245hp
    By gavinbird in forum Outboard Engines
    Last Post: 11-20-2014, 06:14 AM
