Results 1 to 6 of 6
    Nov 2019
    Canada
    Warped Adapter Plate
    Has anyone had success machining adapter plates? I've got a motor here with warped plates, about .006 on both the upper and lower plates.
    Thanks in advance.
    Blake
    www.InjectorService.com
    Call/Text - 204-326-0390
    After block bases rot out , they get welded and surfaced.
    And yes , even adapter plates ... (they all get new dowel pins as well. The newer ones get more of a taper .. makes it easier to install the powerhead)
  3. Likes rgsauger, Forkin' Crazy liked this post
    Nov 2019
    Canada
    Thanks Chaz, I seemed to have missed this reply. That will be a great help going forward!
    Apr 2020
    South Carolina
    Hi Chaz,
    I tried sending you a PM, but it said your box was full. I sent you a message using the email option.
    I just cleaned out 9 pages of PM's ..
    Try me again , please. If I don't know you already or am expecting an E-mail , chances are good you went to the spam folder or deleted ...
    Apr 2020
    South Carolina
    PM sent
  1. Warped adapter plate?
    By Ron V in forum Technical Discussion
    Last Post: 08-02-2012, 10:41 PM
  2. Mercury Tech: 2.0/2.5 Exhaust Divider Plate warped
    By sschefer in forum Technical Discussion
    Last Post: 01-23-2010, 12:45 PM
  3. Adapter Plate ?
    By Carter Powell in forum Technical Discussion
    Last Post: 02-06-2008, 11:35 AM
  4. 280 adapter plate vs 260 with oval tuner adapter plate?
    By rpm racing in forum Technical Discussion
    Last Post: 04-25-2005, 10:06 AM
