Results 1 to 14 of 14
Thread: Combustion chamber size
09-25-2021, 10:58 AM #15000 RPM
- Aug 2007
- Manchester Iowa
- 138
- 31
I am changing heads on my 225 pro max the original heads combustion chamber measures 2.423 in diameter and the other two sets measure around 2.296. the other sets of heads are milled to 33 cc is this why? are they ok to use?
09-25-2021, 12:39 PM #25000 RPM
- Aug 2007
- Manchester Iowa
- 138
- 31
MY mistake the smaller chamber heads are 34 cc anyone?
09-25-2021, 12:55 PM #3
That would be fine if you use good gas.
RockTeam Junk
09-25-2021, 03:52 PM #45000 RPM
- Sep 2014
- Iowa
- 280
- 16
- 44
- 89
Go ahead and check compression with a fresh battery, but 34's and 91 are par for the course for a promax. With 34's and a fairly worn promax my compression is 139-142, with 150 being the limit for 91 octane. Might be worth checking which head gasket thickness you are using, there are 0.75mm, 1mm, and 1.2mm, which will have an effect on compression.
09-25-2021, 06:38 PM #55000 RPM
- Aug 2007
- Manchester Iowa
- 138
- 31
I will check the gasket thickness compression was a even 130 see what it is with new heads previous owner had too many spark plug threads stripped on factory heads coil in one needs more thanks everyone for the help!
09-26-2021, 09:16 AM #6Supporting Vendor
- 11,838
- 163
- 11
- 795
My standard build on 225 Pro Max consists of a 34cc head utilizing a 1mm head gasket , at sea level will yield 138-142 lbs compression with fresh rings and bores which is safe with 91 octane with no more than 25 degrees timing ..
good luck ,
Jay @ JSREJay @ JSRE
Dave Strong liked this post
09-26-2021, 09:19 AM #7Supporting Vendor
- 11,838
- 163
- 11
- 795
Btw , to repair damaged spark plug threads I use only Time Serts for ALL my thread repairs works great for 20 years
Jay @ JSRE
Dave Strong, XP300 liked this post
09-26-2021, 06:42 PM #85000 RPM
- Aug 2007
- Manchester Iowa
- 138
- 31
Thanks for the info I put the 34 cc heads on today the timing is set to 24 degrees the boat ran great! Should I go to 25 degrees? the motor has unknown hours but was rebuilt about 6 years ago.
09-27-2021, 10:54 AM #9Supporting Vendor
- 11,838
- 163
- 11
- 795
Will help bottom and mid range a smig I like it a bit safe at 24
Jay @ JSRE
09-27-2021, 10:57 AM #10Supporting Vendor
- 11,838
- 163
- 11
- 795
I’d spend the time to dial indicate ALL holes shoot timing at full advance on ALL holes find your “high” hole and use it as your constant, call and I’ll explained
832 597 2603Jay @ JSRE
rgsauger liked this post
09-27-2021, 06:11 PM #115000 RPM
- Aug 2007
- Manchester Iowa
- 138
- 31
I will do than thanks Jay.
09-27-2021, 10:19 PM #12
stas1000 liked this post
09-27-2021, 10:20 PM #13
09-28-2021, 06:29 AM #14Supporting Vendor
- 11,838
- 163
- 11
- 795
TY glad to be back helping out with 2.5 issues …
crossflow combustion chamber design
By mike1 in forum Technical DiscussionReplies: 20Last Post: 06-03-2013, 11:37 PM -
Bridgeport combustion chamber size
By vector mike in forum Technical DiscussionReplies: 8Last Post: 05-08-2006, 02:32 PM -
Combustion Chamber Inserts?......
By sosmerc in forum Technical DiscussionReplies: 2Last Post: 01-19-2005, 11:01 AM -
OMC combustion chamber volume?
By bw1969 in forum Technical DiscussionReplies: 1Last Post: 02-24-2002, 08:38 PM -
Combustion chamber volume....
By Superdave in forum Technical DiscussionReplies: 6Last Post: 01-27-2002, 11:11 PM
