Results 1 to 13 of 13
    Manchester Iowa
    Head bolt torque
    My service manual says 30 Ft Lbs then a additional 90 degree turn for head bolt torque on my 225 pro max, is the way everyone is torquing there heads?
    Aug 2015
    Southeast
    Sure someone with more experience will chime in... but I think that's for when using new bolts. I think you are prone to break some off if they are being reused. Seems like I've read a torque spec for used bolts. Hopefully someone will share. I have broken one off.
    STV ProComp w/ 225 Promax
    STV Procomp with 280
    25 Liberator "The Battleship"
    Blazer 650 Pro Tour
    Pekin, IL
    It is for new bolts. For used bolts I have always torqued to 35 lbs.
    Rock
    Team Junk
    Manchester Iowa
    I don't have new bolts what would you torque used ones too?
    Manchester Iowa
    35 LBS no extra turns?
    Houston, TX
    Quote Originally Posted by Merc Speed View Post
    Correct. And walk them up in graduations. 15 pounds on all of them and then 25 pounds on all of them and then finish at 35 on all bolts.
  7. Likes 99fxst99 liked this post
    Manchester Iowa
    Thanks everyone for help with this mornings project hopefully boating today!
  9. #8
    Pekin, IL
    Be sure to oil the threads.
    Rock
    Team Junk
  10. #9
    Manchester Iowa
    Thanks Rock I will do that if you can help with my new post about combustion chamber size please do.
  11. #10
    Los Angeles Cal.
    If you use new head gaskets make sure and recheck torque after running the motor. Generally they will stay stable after two or three heat cycles.
  12. #11
    Dec 2001
    Streachy bolts........the 30 than 90/0 bolts are streach to yeald......I have re/used them...... but when taken down they seem losse.......they have a slash mark at the bottom of the bolt/thread......those are streachy bolts.........the ones to use are the early ones.......w/out the slash........30.... rod bolts..... 35 .....main bolts..... 40 head bolts......and when ya do the last head bolt..... is gives...... darn....break out the kit.......
  13. #12
    Manchester Iowa
    Can you still buy the old head bolts or am I better off to install a stud kit over the winter? I have rechecked torque once I will again next time I run it.
  14. #13
    Houston, TX
    They are around but studs sure are nice. If you have time and $$, then hard to argue with studs.
  15. Likes phillnjack liked this post
  1. Head bolt torque sequence
    By "Aquahaulinass" in forum Technical Discussion
    Last Post: 05-04-2021, 07:33 AM
  2. Head bolt torque for 2.5
    By Little Jon in forum Technical Discussion
    Last Post: 12-06-2013, 12:10 PM
  3. Mercury Tech: 3.0 Head Bolt torque?
    By RedonYellowKillaFellow in forum Technical Discussion
    Last Post: 10-26-2013, 09:50 PM
  4. Mercury Tech: Head bolt torque
    By FAST-J in forum Technical Discussion
    Last Post: 09-06-2012, 01:58 PM
  5. Mercury Tech: Head Bolt Torque ?
    By Dart'nFart'n in forum Technical Discussion
    Last Post: 05-25-2009, 08:53 AM
