Results 1 to 13 of 13
Thread: Head bolt torque
09-25-2021, 04:36 AM #15000 RPM
- Aug 2007
- Manchester Iowa
- 138
- 31
Head bolt torque
My service manual says 30 Ft Lbs then a additional 90 degree turn for head bolt torque on my 225 pro max, is the way everyone is torquing there heads?
09-25-2021, 06:43 AM #26000 RPM
- Aug 2015
- Southeast
- 1,070
- 134
- 80
- 48
- 615
Sure someone with more experience will chime in... but I think that's for when using new bolts. I think you are prone to break some off if they are being reused. Seems like I've read a torque spec for used bolts. Hopefully someone will share. I have broken one off.
STV ProComp w/ 225 Promax
STV Procomp with 280
25 Liberator "The Battleship"
Blazer 650 Pro Tour
09-25-2021, 06:48 AM #3
It is for new bolts. For used bolts I have always torqued to 35 lbs.
RockTeam Junk
09-25-2021, 07:21 AM #45000 RPM
- Aug 2007
- Manchester Iowa
- 138
- 31
I don't have new bolts what would you torque used ones too?
09-25-2021, 07:37 AM #55000 RPM
- Aug 2007
- Manchester Iowa
- 138
- 31
35 LBS no extra turns?
09-25-2021, 07:48 AM #6
99fxst99 liked this post
09-25-2021, 07:51 AM #75000 RPM
- Aug 2007
- Manchester Iowa
- 138
- 31
Thanks everyone for help with this mornings project hopefully boating today!
09-25-2021, 10:00 AM #8
Be sure to oil the threads.
RockTeam Junk
09-25-2021, 11:00 AM #95000 RPM
- Aug 2007
- Manchester Iowa
- 138
- 31
Thanks Rock I will do that if you can help with my new post about combustion chamber size please do.
09-25-2021, 02:04 PM #10Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 404
- 3030
- 5316
If you use new head gaskets make sure and recheck torque after running the motor. Generally they will stay stable after two or three heat cycles.
09-25-2021, 05:25 PM #11Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Streachy bolts........the 30 than 90/0 bolts are streach to yeald......I have re/used them...... but when taken down they seem losse.......they have a slash mark at the bottom of the bolt/thread......those are streachy bolts.........the ones to use are the early ones.......w/out the slash........30.... rod bolts..... 35 .....main bolts..... 40 head bolts......and when ya do the last head bolt..... is gives...... darn....break out the kit.......
09-27-2021, 06:17 PM #125000 RPM
- Aug 2007
- Manchester Iowa
- 138
- 31
Can you still buy the old head bolts or am I better off to install a stud kit over the winter? I have rechecked torque once I will again next time I run it.
09-27-2021, 08:09 PM #13
They are around but studs sure are nice. If you have time and $$, then hard to argue with studs.
phillnjack liked this post
Head bolt torque sequence
By "Aquahaulinass" in forum Technical DiscussionReplies: 12Last Post: 05-04-2021, 07:33 AM -
Head bolt torque for 2.5
By Little Jon in forum Technical DiscussionReplies: 25Last Post: 12-06-2013, 12:10 PM -
Mercury Tech: 3.0 Head Bolt torque?
By RedonYellowKillaFellow in forum Technical DiscussionReplies: 2Last Post: 10-26-2013, 09:50 PM -
Mercury Tech: Head bolt torque
By FAST-J in forum Technical DiscussionReplies: 2Last Post: 09-06-2012, 01:58 PM -
Mercury Tech: Head Bolt Torque ?
By Dart'nFart'n in forum Technical DiscussionReplies: 2Last Post: 05-25-2009, 08:53 AM
