Results 1 to 4 of 4
09-23-2021, 01:24 PM #15000 RPM
- Sep 2006
- 456
- 160
- 9
- 43
- 49
Port Side 200 efi cooler then starboard by 10 degrees F
Does the portside of the v6 naturally run a cooler then starboard? The Stb side dumps more water then the ports out the dump tubes from the head at idle . Motor has 143 stats. Using heat gun at various locations for the readings.
09-24-2021, 06:47 AM #2
As long as you are within the operating temperature range it shouldnt matter too much. What were your actual temps?
coffeeguy thanked for this post
09-24-2021, 08:46 AM #35000 RPM
- Jun 2018
- Orlando
- 100
- 15
- 9
- 67
- 41
pretty normal for stbd cylinder head to run a little warmer because it's higher up and heat rises to the highest point. Not an issue as long as temps are in the right range.
09-24-2021, 06:50 PM #45000 RPM
- Sep 2006
- 456
- 160
- 9
- 43
- 49
Temps were in range but just the difference and less flow from port thermostat
Mercury Tech: remove 1998 Mercury Optimax starboard lower cowling, fuel cooler replacemenent.
By Salmonbarry in forum Technical DiscussionReplies: 2Last Post: 05-16-2020, 04:59 AM -
Port 20 degrees hotter than starboard ?
By WATERWINGS in forum Technical DiscussionReplies: 25Last Post: 08-16-2007, 09:19 AM
