Results 1 to 15 of 19
09-23-2021, 03:29 AM #15000 RPM
- Mar 2020
- netherlands
- 163
- 14
Whats the point of this high performance part
Hello,
I was wondering, what does this thing specifically do? I can think of 2 things:
Its the same as a hydrofoil but smaller and cooler (i doubt this since most of the high prf. guys run LWP's and the plate is above the water
2: it keeps water from going up, above the plate, directing this water to the propellor, and thus giving the prop more water/ slip?
Othrr then its just cool looking, when should one consider installing this, and is there a notable difference? So yes, what is the difference.
Thanks!
Eh2000 thanked for this post
09-23-2021, 05:29 AM #25000 RPM
- Sep 2011
- Deplorableville
- 740
- 1347
- 76
- 3211
- 1452
It will help your hole shot and it will also let you plane at a lower speed.
09-23-2021, 09:59 AM #35000 RPM
- Mar 2020
- netherlands
- 163
- 14
Why does it do that? What the theory behind it? Does it trap more water beneath the cavitation plate?
09-23-2021, 10:43 AM #4Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 405
- 3032
- 5318
When the boat launches it puts pressure in the rear causing the bow to lower.
pkstv thanked for this postphillnjack, gmorgan liked this post
09-23-2021, 12:49 PM #5Team Member
- Lake Coochiching, Ontario
- 7,768
- 276
- 487
- 1590
- 6 Post(s)
I had a Hydrostream Virage (mod tunnel) that was hard to plane with an over hub prop. I put on a Bob’s true tracker. It was a huge improvement. Instead of revving to 5000 and waiting, the boat just planed
phillnjack liked this post
09-23-2021, 01:56 PM #6
Yes. Think hydrofoil and how it creates lift, same principle. On my application, it would keep stern up and bow down getting on and off plane. My Allison XB used to take on water over the stern if you didn't ease off the throttle. Now you can drop it and hardly a drop will come in. After the boat gets on plane it is out of the water, so no drag to speak of.
09-23-2021, 03:23 PM #7
Helped my bullet to run at lower speeds without porpoising
pkstv liked this post
09-23-2021, 06:07 PM #85000 RPM
- Aug 2007
- Manchester Iowa
- 138
- 31
Agree my Hydrostream Vasseret was porpoising up to 30 MPH with the bobs tracker now can run 18 MPH on plane.
10-03-2021, 06:27 AM #9
Great for holeshot. but once on plane should NOT be touching water....this " Allison type" is the coolest looking foil around.
Forkin' Crazy, pkstv liked this post
10-03-2021, 04:45 PM #105000 RPM
- Aug 2007
- Manchester Iowa
- 138
- 31
I leave mine all the way down for a slow smooth cruise on plane then lift it up for faster speeds.
10-05-2021, 01:28 PM #11Supporting Vendor
- 11,838
- 163
- 11
- 795
Always helped my race boat “set” quicker …
Jay @ JSREJay @ JSRE
10-11-2021, 11:15 AM #12
Now that I have my mirage together it does take like 20 seconds to plane. Bow goes way up and it blows out to 5000 rpm then hooks up and drops back down. I know you are running a completely different mid and setback, and so is Kevin here, but do you know if theres an easy way to correct that? It does it pretty much the same no matter what style prop I run.
And what is the performance difference between a hydrofoil like the one pictured in this thread and a blow-out plate bolted to the transom in front of the motor? As I understand they do the same thing, but is there a preference or different function?
10-11-2021, 07:57 PM #13Team Member
- 7,768
- 276
- 487
- 1590
- 6 Post(s)
[QUOTE=25two.stroke;3311976]Now that I have my mirage together it does take like 20 seconds to plane. Bow goes way up and it blows out to 5000 rpm then hooks up and drops back down. I know you are running a completely different mid and setback, and so is Kevin here, but do you know if theres an easy way to correct that? It does it pretty much the same no matter what style prop I run.
That was my experience with my old Hydrostram Virage, and a Bob’s True Tracker completely cured it. I would like to know the relative benefits of the Allison skid planer and their foil. I have an Allison foil on my SS2000 now
10-12-2021, 07:30 PM #14
That depends. Mine would dig sometimes and water would run up the jack plate and slap the motor. The wing or cap on the back of the jack plates helps sometimes. The Allison style wing is pretty easy to make. I used 3/16" if I remember right.
Where does your exhaust exit? Around the prop?
10-13-2021, 04:10 PM #15
Forkin' Crazy liked this post
Article: High Performance Propellers, the Hoss Way! Part 1
By Scream And Fly in forum vBCms CommentsReplies: 12Last Post: 09-13-2015, 06:27 PM -
Whats a good starting point for setback?
By jimmyz32 in forum Props, Setup, and RiggingReplies: 5Last Post: 08-02-2009, 09:17 AM -
So, what was the high point of your year?
By chris_lacey in forum The Scream And Fly LoungeReplies: 5Last Post: 12-22-2004, 11:42 PM -
High Point NC
By tluckam in forum General Boating DiscussionReplies: 0Last Post: 07-25-2003, 09:43 PM -
ODBA High Point Champions
By CRyan in forum General Boating DiscussionReplies: 0Last Post: 10-19-2001, 10:37 PM
