Results 16 to 30 of 37
    Apr 2016
    Port perry
    Ya I never really thought about making sure that they were all the same no mixing but would love more people thoughts about cdi oem and mixing
  2. #17
    Jul 2005
    AZ
    Quote Originally Posted by 91 charger stv View Post
    I'm not stuck on what h20 has suggested yet just the only set up I've hears so far so thought I would price it out and yes I already have the bearing carrier
    Oh ok.. just figured you might because everyone seems to crap all over the stock electronics setup and complain about CDI stuff and always looking to build a better mouse trap.. lol
    Well you usually just hear tbe problems not tbe ive had the motor 30 years never had a problem..
    Well i DEFINITELY like the CDI DIGITAL setup ON mine
    Fixes the little stuff.. doesnt need to spin 600 rpm to get spark gets it from tbe battery.. they start cold with little more than a tap of the switch. Batteries can but pretty low and still have no problem starting..etc
    '84 Checkmate Convincor
  3. #18
    7 Post(s)
    Only problem I ever had w/a CDI part was trying their digital system on a looper.
    Talked a customer into it as an experiment and failed miserably.
    Held the the phone up to it while running so CDIs tech guy could hear it ��
    And, H2O has forgotten more about this stuff than most will ever know and is finishing the most evil, home brewed V-6 looper on the planet.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  4. #19
    Jul 2005
    AZ
    Why i thought he would go with that setup..
    And that motor is insane..need more pics and a video walk around..
    And, H2O has forgotten more about this stuff than most will ever know and is finishing the most evil, home brewed V-6 looper on the planet.[/QUOTE]
    And see youll always find someone who doesn't like the setup.. lol
  5. #20
    Apr 2016
    Port perry
ID:	493465Click image for larger version.
ID:	493466Click image for larger version.
ID:	493467Click image for larger version.
ID:	493468Click image for larger version.
ID:	493469Click image for larger version.
  6. #21
    Apr 2016
    Port perry
    So this what I got with the flywheel I forgot he gave ame a stator not sure if it's good or not or which one it even is?
  7. #22
    Jul 2005
    AZ
    Ive never used a gold flywheel on a looper... Want to see how this works out..
  8. #23
    Apr 2016
    Port perry
    Well we will all find out next spring once I get a good plan figured out first
  9. #24
    MIAMI FLORIDA
    The stator you have in the pics will work, but the dual driver coils work better for starting and top end if you turn it up, The magnets in the gold wheels are not that strong so extra coils help out with the voltage. That's a V4 looper upper bearing and you will need it, I was going to say in the last post i had one if you needed it. The small regulators have gone up in price but you can buy the v4 10 amp water cooled for less than 100 or use the old air cooled external mount crossflow regulator that just grounds 1 of the stator legs so its charging full or 1/2 not really a regulator, i think pro marine is cheaper on those than cdi. This will work from pro.153-3408 : Rectifier 3 Wire Ring Terminal. or if you want water cooled193-4205 : Voltage Regulator, 10amp
  10. Likes mrichartz liked this post
  11. #25
    MIAMI FLORIDA
    New oem will be CDI depending on how old the stock you get is. I wont say any more about ebay LOL... Yea hopefully Stoker will chime in...
  12. #26
    Apr 2016
    Port perry
    Ya I hope so too I mean if all I can find is cdi then I guess I'm stuck with it would love to just start with all omc fresh from the box but good luck with that it seems
  13. #27
    Sep 2008
    charlestown, ri
    might be a dumb comment, but you were saying packs were going out... did you check for any voltage on the black/yellow kill wire ?
  14. #28
    Apr 2016
    Port perry
    No like I said it's the end of the year and I kinda new I was switching up electronics so I didn't make an effort to diagnose my problem
  15. #29
    May 2001
    Hickory NC
    If your 35 amp original regulator is good they will work fine on the 10 amp system. If it ever goes bad replace with the 85/7 10 amp V4 looper version to save a few bucks. I have not had any kind of luck with CDI ignition on an OMC but seems fine on Merc. Depending on your use and target rpm you may be fine with the 6700 boxes, the limiter can be removed. I will have to look for to see if I still have the drawing on how to remove. As for stator the V8 F1 is the best but extremely had to find (blue in color), they were set up to run 4 power packs, next would be a green one from a 79 to 82 V6 crossflow as a good one will produce 300 volts to ignition.
    Gary it is the V4 looper top cap from85-7 and the 85 V8. If someone has a lathe the stator mounting towers can be turned down on the stock V6 looper bearing, did that many times.
    Charger if you are having the issues you mentioned with your powerpacks stay away from CDI and run oem. Make sure they have a good clean ground and a good stator with either 10 or 35 amp. Consistent pack issues are a result of other problems. I have run the dual and single pack systems over 9000 with the gold flywheel and a good stator, remember the packs can only release the energy they receive from the stator. If pack gets 200 volts from stator the coils will only receive 200 from packs. In my experience it takes 250 volts or more to run clean at 7000 and 280 plus to turn 9.
  16. Thanks Instigator thanked for this post
    Likes Instigator, MattGreen, greg3 liked this post
  17. #30
    7 Post(s)
    Al, I have measurements in my notes for the upper carrier tall to short.
    Never done it but looks easy enough.
    Thanks for responding w/some priceless info.
  1. Build my intruder back or build a black motor..advice needed!
    By Twilliams4003 in forum General Boating Discussion
    Last Post: 01-05-2021, 07:56 AM
  2. Best workstand to build powerheads? Build? Buy?
    By Zoomba in forum Technical Discussion
    Last Post: 03-10-2014, 07:45 PM
  3. Build better and Safer Build Union
    By SnakeBit in forum The Scream And Fly Lounge
    Last Post: 09-06-2008, 05:00 PM
  4. DK's Vindicator
    By DK in forum Technical Discussion
    Last Post: 08-10-2003, 09:49 PM
