Results 1 to 2 of 2
Thread: Merc V6 Swivel Tube bushings
09-21-2021, 06:46 AM #1Member
- Mar 2016
- N/A
- 63
- 7
Hi,
The swivel housing bushings are pretty shot on my 225 promax. I've stripped the Swivel housing down and there doesn't appear to be and bushes in the lower section but was a thin aluminum bushing in the top.I have a set of part number 23-847726 buhes but these are about .100" bigger in Diameter. I have read about bushes being made and pressed in, are this available to buy? Does the lower section need machining out to take a bush? It looks as though there is a recess for a seal but no bushing. If not what material is normally used and does anyone have any dimensions please?
ThanksLast edited by rs2.2; 09-21-2021 at 08:17 AM.
09-22-2021, 12:33 PM #2Member
- May 2016
- Upper Potomac River
- 71
- 9
I have no dimensions but I would make some out of Delrin
1990 Merc V6 swivel bushings
By Miles B in forum Technical DiscussionReplies: 5Last Post: 12-12-2018, 12:48 AM -
Tilt Tube and Swivel Tube Bushings?
By 2.5-21 in forum Technical DiscussionReplies: 1Last Post: 09-02-2016, 08:17 PM -
Swivel bushings.??
By dagodiver in forum Technical DiscussionReplies: 4Last Post: 03-12-2014, 10:23 PM -
Merc V6 Swivel Bracket bushings and injector questions
By contentsunderpsi in forum Technical DiscussionReplies: 0Last Post: 05-26-2012, 10:35 AM -
Mercury Tech: swivel pin bushings
By speedinstream in forum Technical DiscussionReplies: 11Last Post: 12-15-2010, 09:14 PM
