Results 1 to 8 of 8
Thread: Possible Fuel Injector Damage?
09-20-2021, 03:03 PM #1Member
- Sep 2021
- Baltimore, MD
- 31
I recently replaced the high pressure fuel pump on my motor, 2.5L EFI and now I have all kinds of issues. After allowing it to run for a few minutes, and noticing it ran poorly, I checked the fuel pressure and it was 85 psi. After cleaning the regulator the fuel pressure is now at spec but the engine still has some serious issues - idles high, runs rough, bogs down at 3000 rpm. Could the excessive pressure have damaged a fuel injector(s)?
09-20-2021, 03:07 PM #2
Chances of that are extremely low. These are the hose feed style injectors I'm assuming?
www.InjectorService.com
Call/Text - 204-326-0390
09-20-2021, 03:08 PM #35000 RPM
- Sep 2017
- ontario
- 717
- 68
- 43
- 73
- 171
I would think a DDT would be helpful .
09-20-2021, 03:56 PM #4
I would think junk the reg and get a new one and send out the injectors. If you "cleaned" the regulator and it worked something is now in your injectors.
1973 Viper - sold
1978 Viking - sold
1995 XB02
09-20-2021, 04:06 PM #5Member
- Sep 2021
- Baltimore, MD
- 31
09-20-2021, 04:08 PM #6Member
- Sep 2021
- Baltimore, MD
- 31
That's what I am now thinking. Ever since I "cleaned" the regulator its been running really bad and progressively getting worse, tons of smoke, high and rough idle and alarms.
Thanks for the input
09-21-2021, 09:26 AM #7
Have you looked in the rail or had the injectors out? Its never a bad idea to have them cleaned, but to answer your question, no they will not be damaged. Dirty, plugged....probably, but not damaged.
09-21-2021, 10:00 AM #8Member
- Sep 2021
- Baltimore, MD
- 31
Thanks. I had them out and sent them to be professionally cleaned a few years ago but not after this recent issue. May I ask a follow-up question, Can a faulty or clogged fuel injector be suspected by looking at the spark plugs after only a little bit of time running, maybe less than an hour?
Fuel Injector
By stevemx45 in forum Technical DiscussionReplies: 4Last Post: 05-01-2019, 08:39 AM -
Yamaha Fuel Injector
By crimson merc in forum Parts WantedReplies: 1Last Post: 09-03-2015, 09:44 AM -
Leaking Fuel Injector hose from rail. Need to replace injector?
By nburgart in forum Technical DiscussionReplies: 6Last Post: 08-26-2014, 12:57 AM -
OMC Tech: electric fuel pump 235 small bore,, is it safe of fire hazard or possiable damage
By tedd930 in forum Technical DiscussionReplies: 1Last Post: 05-17-2011, 09:43 AM
