Results 1 to 4 of 4
Thread: Mercury - Clean Power Circuit
09-19-2021, 09:24 AM #16000 RPM
- Nov 2006
- 1,491
- 13
- 129
- 70
- 626
- 35 Post(s)
I'm currently doing a Merc V8 ProXS repower project and have encountered a wiring circuit that is new to me (Installation manual).
What is a "Clean Power" circuit? (2 wire 5 amp fused circuit directly from starting battery to ECM via 2 wire connector)
The circuit is non-switched and provides 12VDC to the ECM on a continuous basis?
Why not have a "jumper" circuit connected to the battery leads at the engine instead of 2 wires going all the way back to the starting battery?
What happens to the ECM when the circuit is disconnected? System reboot? Memory wipe?
06-14-2022, 10:20 AM #2The Historic Photo Master
- Jan 2004
- Florida
- 37,827
- 64
- 1667
- 337
- 19201
- 3 Post(s)
...older post. what did you learn on this zebra?...
06-14-2022, 09:34 PM #36000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
Clean power powers the bus. It's critical to have good unmolested power.
06-17-2022, 01:37 PM #46000 RPM
- Nov 2006
- 1,491
- 13
- 129
- 70
- 626
- 35 Post(s)
Clean Power Lesson
Nothing really. It's wired per installation manual. Still does not make any sense if the ground path is common and a "ecu jumper" wire is connected to the engine's positive battery terminal. Doesn't change a thing when it comes to circuit load / drain. I wish a Mercury electrical engineer would answer this post?
clean 1998 260 power head
By Michael J Giesler in forum Outboard EnginesReplies: 32Last Post: 07-22-2016, 11:38 AM -
Article: Mercury Racing Blog: Clean Power for the European Union
By Scream And Fly in forum vBCms CommentsReplies: 0Last Post: 03-21-2013, 01:20 PM -
old pics of a mini power boat racing circuit!!
By chrisr in forum General Boating DiscussionReplies: 4Last Post: 02-14-2009, 01:40 PM
