Results 1 to 15 of 16
Thread: Tips of 25 years
09-16-2021, 07:08 AM #1Supporting Vendor
- 11,838
- 163
- 11
- 795
Tips of 25 years
Had interesting conversation last night about my absents from S&F well long story but due to several inquiries I’m going to try and help as long as I’m allowed .
How many of us have stripped the heads off Reed plate screws because the application of red loctite … Well found a method that eliminates that issue, I put the complete cages from motor and install in toaster oven and heat to 400 degrees while hot submerge in ice water , after cooling the screws can be removed by hand no more stripped heads. Then when assembly use blue loctite , problem solved ..
Jay @ JSREJay @ JSRE
powerabout, SS Minnow, kellytheaker, ssv1761982, Bodhi, Greg G, trivialpursuits, time warp, phillnjack thanked for this postsonicss33, SS Minnow, LakeFever, 89LASER, mrichartz, Forkin' Crazy, Dd24skater, scott reierson, phillnjack liked this post
09-17-2021, 08:07 AM #2Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
I hate the smell of burning epoxy,I tie wrap the trigger on a soldering iron so it stays hot.Touching the tip to the screw head 3-4 seconds kills the locktite and the screw comes out easily.Good to see you back,Chris
trivialpursuits, time warp thanked for this post
09-17-2021, 10:20 AM #3Supporting Vendor
- 11,838
- 163
- 11
- 795
Thanks !
As I’ve always said the suggestions and tips I post on is something that I’ve found works for me for 25 years others also have great methods that’s worked for them , when ALL come forward with useful methods the skill level over all rises …
LakeFever liked this post
09-17-2021, 10:49 AM #4
I've shoved rope into the spark plug hole to act as a stop when removing the flywheel nut if it's difficult to grab the flywheel to hold it. hf...
09-17-2021, 11:01 AM #5
Good tips!
www.InjectorService.com
Call/Text - 204-326-0390
09-17-2021, 06:38 PM #6The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
...don't pickup a dropped needle bearing with magnet...
09-17-2021, 07:20 PM #7
Don't use a flashlight with a magnet base when building gearcases...somehow the needle bearings will always find their way to that magnet on your bench...
Jay I'm glad to see you here and look forward to hearing all you have to offer! And thanks for talking to me about that mystery canister that was in the Mirage I bought!
09-18-2021, 07:49 AM #8Supporting Vendor
- 11,838
- 163
- 11
- 795
Glad to help !!
Jay @ JSRE
09-18-2021, 07:50 AM #9Supporting Vendor
- 11,838
- 163
- 11
- 795
BTW our new web site is
www.jaysmithracingengines.com
for interested parties .
Come and visit our new 5000 square foot shop .
jayLast edited by Jay Smith; 09-18-2021 at 09:22 AM.
Jay @ JSRE
scott reierson thanked for this post
09-18-2021, 12:56 PM #10
"PSA Warning"
For anyone that owns something newer than 25 years old or is anything other than a 260 based era engine .. 400*f will quickly put 25 years of dry rot on your rubber coated reed cages . If you have already done this ... your in luck , Chris Carson makes an over size reed for cages with the rubber removed and the cage lapped in.
375 - 400* is perfect for those who wish to coat their own pistons.
If you can generate fifty more degree's , you can drop the sleeve's out of the block .. steel of course .. them other ones are like CH3NO2 racin ... a fella's got to hate money ..
trivialpursuits thanked for this post
09-18-2021, 02:51 PM #11The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
...when rebuilding the old inline sixes, don't forget to install new little plastic bleed restrictor plugs in the bottom corners of the intake ports. it will idle better. they pop out whenever the powerhead gets steamed or too hot from questionable water pressure/volume. they are only in the bottom five, of the six intake ports...
09-18-2021, 03:54 PM #12Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
I use a rounded end punch at varying angles to close down the opening to around 020,and never have to deal with em again…most folks don’t know the’re there…if you need pistons I have plenty 015,030,and 040,high dome…
09-18-2021, 05:58 PM #13Supporting Vendor
- 11,838
- 163
- 11
- 795
Good info y’all
Jay @ JSRE
09-21-2021, 04:14 AM #14
I've got a hack.
The 8 spline on a v6 Merc drive shaft can be held/torqued with a regular 12 spline socket with either 2 or 4 pinion bearing needle rollers in the shaft spline.
I can't recall offhand what size socket to use but one does fit.
powerabout liked this post
09-21-2021, 04:31 AM #15
Doing any fiberglass lays and don’t know how much resin to catalyze? You need 0.65ml of resin per square inch of 1708
Show us yer Tips !!!!!!
By phillnjack in forum Props, Setup, and RiggingReplies: 4Last Post: 10-13-2016, 04:23 PM -
Tips on pumping gas
By Moonshot180 in forum The Scream And Fly LoungeReplies: 44Last Post: 05-10-2008, 02:45 PM -
Any hop up tips for a 98 Pro Max SS
By Larry33kc in forum Technical DiscussionReplies: 12Last Post: 11-27-2006, 08:19 AM -
moving tips
By bulldogdaddy in forum The Scream And Fly LoungeReplies: 3Last Post: 02-27-2005, 02:34 PM -
Kid Tips
By Flat Out in forum Boating Safety and Safety EquipmentReplies: 2Last Post: 10-20-2001, 01:27 AM
