Results 16 to 16 of 16
Thread: Tips of 25 years
09-21-2021, 02:36 PM #16Supporting Vendor
- 11,838
- 163
- 11
- 795
Needle bearing rod surfaces …
Have a great friend that’s IMO one of the best master techs on the planet . You might know him as Half Fast ( Chris Justice ) he’s a great source of tricks of the trade , years back he taught me that needle bearings prefer a slight texture instead of a chrome look , this allows the needle to roll instead of slide which max perfect sense. So for 15 years I’ve cleaned the crack cap surface with a SS brush , chase the loctite from threads , assemble crack capped surface and slightly torque . After torqued check cracked surface for perfect fit , I then use a 400 grit ball hone on big and small rod ends and slightly scuff the surfaces so there is a slight texture ,this has worked grand for me for 15 years , thanks Chris timeless tip from great knowledgeable friend …
Jay @ JSREJay @ JSRE
time warp thanked for this post
Show us yer Tips !!!!!!
By phillnjack in forum Props, Setup, and RiggingReplies: 4Last Post: 10-13-2016, 04:23 PM -
Tips on pumping gas
By Moonshot180 in forum The Scream And Fly LoungeReplies: 44Last Post: 05-10-2008, 02:45 PM -
Any hop up tips for a 98 Pro Max SS
By Larry33kc in forum Technical DiscussionReplies: 12Last Post: 11-27-2006, 08:19 AM -
moving tips
By bulldogdaddy in forum The Scream And Fly LoungeReplies: 3Last Post: 02-27-2005, 02:34 PM -
Kid Tips
By Flat Out in forum Boating Safety and Safety EquipmentReplies: 2Last Post: 10-20-2001, 01:27 AM
