Results 1 to 15 of 15
    Jun 2018
    Floating around
    Help ID this prop
    Found this 30p x 14" chopper recently. Excellent condition, anyone know what make/model prop this is?
ID:	493117 Click image for larger version.
ID:	493118 Click image for larger version.
ID:	493119 Click image for larger version.
    I'm gunna step forward and say NOT MERC
  3. Likes LakeFever liked this post
    29 srx
    Jun 2018
    Floating around
    I don’t think it’s an SRX. It has three 9’s cast into it. One on each blade near the hub. They are 9’a or 6’s but I think it’s a 999 prop just how it reads to me at least. It’s in damn near perfect condition though
    Mar 2004
    Brooklyn Park, MN
    Looks like an SRX to me. Maybe a 29 worked to a 30? Did anyone copy the SRX prop with how the hub is installed?
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    Jun 2018
    Floating around
    Gents I think your correct.
    https://www.screamandfly.com/showthr...le-Small-Shaft
    Guess its a 29 SRX thats been worked to a 30 and maybe some extra cup added? Hard to tell, Thanks boys
    SRX that's been modified substantially. Reduced diameter and heavily cupped, machined at both ends of the hub probably to fit a Merc shaft better.
  9. Thanks LakeFever thanked for this post
    Jun 2018
    Floating around
    Can hardly wait to try it out. It came with what looks to be a custom made thrust washer too
  11. Likes rjdubiel liked this post
    The SRX hub is too long for a Merc shaft. The machining was to shorten it for a better fit. The thrust washer you have may be thinner too. You'll likely need a cut down nut to install it with a flat washer.
    This is a stock one installed on a Merc. If it doesn't fit right on yours, I'm sure it's Trump's fault according to what I see on Scream and Fly.
  14. Thanks LakeFever thanked for this post
    Likes LakeFever, rjdubiel liked this post
    Jun 2018
    Floating around
    LOL indeed. I'm going to test fit it on a lower now and see how it fits up. Stay tuned
  16. #12
    Jun 2018
    Floating around
    You are correct its been machined to fit and fit it does. Merc washer is brass, SRX washer is stainless color
ID:	493149 Click image for larger version.
  17. Likes 89LASER liked this post
  18. #13
    Somebody did a nice job there, you can get a lock ring on there with a full nut. That prop should have a ton of lift with all that cup.
  19. Thanks LakeFever thanked for this post
  20. #14
    Mar 2004
    Brooklyn Park, MN
    Sell it to me! haha.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  21. Thanks LakeFever thanked for this post
  22. #15
    Nice piece, hate it when I just find items like that
  23. Thanks LakeFever thanked for this post
  1. F1 / F2 Racing Items for Sale!! Dewald props, Performance Prop, Prop test wheel...
    By Spectre Powerboats in forum Misc. Parts and Accessories
    Last Post: 02-20-2018, 03:01 PM
  2. Replies: 1
    Last Post: 02-03-2018, 02:08 PM
  3. OMC Tech: Help! 225 carbed Johnson melting prop hubs / high exaust temps through prop hub
    By Tunnelvision1995 in forum Technical Discussion
    Last Post: 09-12-2017, 08:03 PM
  4. Prop slip on overhub prop related to no exhaust relief?
    By B.Mac in forum Technical Discussion
    Last Post: 10-06-2015, 03:25 PM
