Results 1 to 12 of 12
09-14-2021, 09:00 AM #1New Member
- Apr 2021
- tennessee
Mercury 2.4 225 ring gap? Piston clearance?
Im building a 2.4 225. I found a new old stock block. I ordered a set of pro marine piston kits.. Out of the box the ring gaps all measure .029-.030.. Is this to much gap? Pro marine says they use a different ring material and they can run more gap. I was expecting to have to file them... Im new to 2 stroke engine building so thought i would ask, i don't want to mess up my virgin block lol.. Thanks!
09-14-2021, 06:31 PM #2The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
...welcome to S & F......
CheckvII liked this post
09-14-2021, 06:32 PM #3The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
...you'll have your answer shortly...
09-14-2021, 06:48 PM #4Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Who ya callin' .......short
09-14-2021, 06:57 PM #5Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Reminds me of a thread a while back, wrong pistons ring supplier, went around in circles. Not maybe optimum gap but not going to be a power issue according to some piston manufacturers. How's the bore finished size to piston clearance?
CheckvII thanked for this postroadkill636 liked this post
09-15-2021, 08:30 AM #6New Member
- Apr 2021
- tennessee
Best i can measure with my standard calipers is bores = 3.376-3.377 , bottom of piston skirt largest spot 3.368.. I didn't have my bore gauge with me, but can get a deeper measurement if needed..
09-15-2021, 09:46 AM #7New Member
- Apr 2021
- tennessee
Just talked to Pro marine again. They said there ring tension is different and that .030 was correct"..That it would not affect compression, or leak down. Said it did not matter what the oem merc specs are.. Did they just feed me a line of Sh*t?
09-15-2021, 10:30 AM #8Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Hahaha... linear expansion of the ring vs bore during high heat soak. Gap probably won't meet end to end and pinch with that number.
It's all about the ring seal and how it seats during break-in , at slow speeds or 6000+ the extra little bit of gap isn't going to bleed off according to them.Last edited by FMP; 09-15-2021 at 10:38 AM.
09-15-2021, 11:05 AM #9
Geez... it seems like that would be hard on the retaining pins?
09-15-2021, 12:34 PM #10Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
The rabbit hole
09-15-2021, 12:51 PM #11New Member
- Apr 2021
- tennessee
I was thinking of getting a set of OE rings and using these pistons, since i already opened most of the ring packs to check them.. I havent measured every piston but looks like the pistons will have about .008 clearance..
09-15-2021, 07:21 PM #12Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Let it burn.......
Piston Ring end gap clearance question
By Revenge22 in forum Technical DiscussionReplies: 15Last Post: 03-18-2020, 02:12 PM -
Mercury top pin two ring piston
By Michael J Giesler in forum Misc. Parts and AccessoriesReplies: 2Last Post: 02-17-2016, 08:46 PM -
By Michael J Giesler in forum Misc. Parts and AccessoriesReplies: 12Last Post: 10-20-2015, 07:30 AM -
Blowout ring clearance? How much clearance should there be between the prop...
By in forum Technical DiscussionReplies: 1Last Post: 07-01-2001, 03:12 AM
