Results 31 to 45 of 77
Thread: 2021 Parker Enduro
09-29-2021, 10:12 PM #31
Ever check for center of gravity?
It's easy. Of course, you'll need a commercial drive-on scale, or some other way to measure your weights.
(1) Weigh your trailer empty. Record the weight readings at the axles, and then at the tongue. With this you can get the CG of the trailer by itself.
I'm just making up numbers here, but let's say you get 1800# at the axles and 200# at the tongue. Therefore, your trailer weighs 2000#.
The CG is going to be 10% (200 [light end] / 2000 [total]) of the distance from the heavy side (the axles).
Or conversely, 90% (1800 [heavy end] / 2000 [total]) of the distance from the light end.
So, let's say it's 20' from the axles to the tongue. Your CG is 2' from the axles, or 18' from the tongue.
Either way you do it, it will work out the same.
(2) Repeat the weighing with the boat on it this time. Again, record the weight at the axles and at the tongue.
Do the same math with the new numbers to arrive at the CG position of the trailer-boat combo.
Let's say it was 7,800# at the axles and 2,200# at the tongue. The total is 10,000# (2,000 Trailer, 8,000 Boat).
The CG from the axles of the combo would be 2,200 / 10,000 X 20 = 4.4'
From knowing those two positions you can precisely calculate where the boat's CG is.
(3) We're going to do a summation of moments at the axle position, I'm calling that the zero position.
(A moment is also known as a torque expressed as Distance X Force[Weight], i.e. FT-LB, IN-LB, etc.)
So, the moment generated about the axles by the boat-trailer combo is 10,000# X 4.4' = 44,000 FT-LB
We know that the moment generated by the trailer alone is 2,000# X 2' = 4,000 FT-LB
So, from that we can compute that the necessary moment that the boat needs to generate is 44,000 - 4,000 = 40,000 Ft-LB.
Thus: 40,000 FT-LB = 8,000# X the distance from the boat's CG to the axles.
40,000 / 8,000 = 5 FT.
So, in this example the distance from the axles to the boat's CG is 5 feet.
Set back will help more than anything.Last edited by CUDA; 09-29-2021 at 10:29 PM.
09-29-2021, 11:32 PM #32
You are absolutely correct on the CG. It is easier to balance a purpose built light race hull vs a ski hull that I was lucky to find for 2k. Part of the fun is taking a performance ski hull and try to make it somewhat competitive.
It brings family and friends together for some good times.
09-30-2021, 06:59 AM #335000 RPM
- Mar 2015
- DFW
- 665
- 16
- 42
- 366
- 232
09-30-2021, 10:23 AM #34
Noah Burns liked this post
10-03-2021, 10:54 AM #35
Keith always appreciate your input and experience running this race. I believe only Johnny's Rampage the #1 or 2 out of the mold. They put a insert in the mold to allow for trim tabs. Jerry built the rest without this space (ski hulls). Because of the transom design, there's no space to mount a small block of aluminum to the transom just above the tunnels to add trim tab plates.
Depending how these mods work in testing, we may have to flip it over next year and add 3/4 to 1" to the top of the tunnels and allow a space at the end near the transom for trim tab plates and may run a flat center pad like others run.
I've done a lot of research and measurements of the different tunnels on hulls like Stokers, Laveycrafts, STV's, Mirages, HST's and Eliminator Daytona's. When Jerry Baker built my blue hull (use to be red when Delbert raced it) he allow space for trim plates and they modified the center pad from being slightly rounded to flat. It also has 7" tall tunnels at the end. Most of the ones I mentioned have 7 to 6 1/2". Some have 1" of squish and some 2 like STV's. Will you be at the F1 race in Havasu?Last edited by Baker343; 10-03-2021 at 11:14 AM.
10-03-2021, 10:58 AM #36
10-03-2021, 11:07 AM #37
Noah Burns, Lake X Kid liked this post
10-04-2021, 12:25 PM #38
10-04-2021, 10:42 PM #39
How wide is that pad above?
So many California boats of that era had such a similar design, Sleekcraft looks much like this below,
Who was the first that everyone copied?
I know Sleekcraft was very involved in jet boat drag racing back in the late 70's 80'sLast edited by CUDA; 10-04-2021 at 10:45 PM.
10-09-2021, 06:19 PM #40
10-09-2021, 06:32 PM #41
10-09-2021, 06:36 PM #42
10-09-2021, 06:37 PM #43
10-09-2021, 09:55 PM #44
mr fun thanked for this post
10-10-2021, 07:59 PM #45
Upcoming Event: 2018 Parker Enduro
By Baker343 in forum General Boating DiscussionReplies: 198Last Post: 06-23-2019, 01:49 AM -
Upcoming Event: 2017 Parker Enduro
By Baker343 in forum General Boating DiscussionReplies: 54Last Post: 12-01-2017, 07:37 AM -
Parker enduro
By AZMIDLYF in forum Upcoming Events, Races, and GatheringsReplies: 0Last Post: 10-28-2017, 02:28 PM -
Parker 300 Enduro
By frankydee in forum Technical DiscussionReplies: 13Last Post: 11-02-2013, 05:47 AM -
Great Vid..Parker Enduro from the 70's
By Robby321 in forum General Boating DiscussionReplies: 15Last Post: 05-16-2009, 07:10 AM
