Results 1 to 1 of 1
09-12-2021, 05:55 PM #1Junior Member
- Jun 2015
- bay area
Mercury 200sx loss of excelaration
Hello I need help with this issue, it's been this way since the rebuilt.
Up to 3/4 throttle the motor accelerates as normal, beyond 3/4 it stops accelerating and remain at the same speed.
It has a Simon programmed ECU, new coils/electronics and alternator. Because of corrosion issues, the two piece exhaust plate was change to a Optimax 150 with the exhaust adapter being machine to match the 200 exhaust tube.
The 26" prop is even with the bottom of the xb2003. Currently the Top speed is 70, ~5700rpm.
Any thoughts on what is causing the loss of power, can the 150 exhaust plate be the issue.
thanks
200sx
By Cblyzes in forum Engines WantedReplies: 1Last Post: 06-03-2019, 12:58 PM -
Mercury Tech: Mercury 2.4 EFI Bridgeport rpm loss
By Tightrig 12 in forum Technical DiscussionReplies: 7Last Post: 09-05-2018, 03:00 PM -
200sx
By Frostman in forum Outboard EnginesReplies: 6Last Post: 03-08-2017, 05:37 PM -
Mercury 92 175 EFI XRi 2.4 L power loss?
By H2Okie in forum Technical DiscussionReplies: 14Last Post: 10-29-2014, 07:15 AM -
200 Mercury loss of RPM's
By mkeleher in forum Technical DiscussionReplies: 20Last Post: 10-10-2013, 05:42 PM
