Results 1 to 3 of 3
Thread: Lower unit gears
09-12-2021, 10:40 AM #1Member
- Apr 2021
- Californian
- 55
Lower unit gears
I purchased a set of gears for my mariner 175 HP on eBay and when I recieved them I noticed the teeth were angled in the oppasit direction as the ones taken out. I purchased all 3 does this matter.
09-12-2021, 05:31 PM #2Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
send them back..... they are for a different case
09-13-2021, 08:03 AM #3Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
pin style cases have this feature make sure which case you have there is a casting number located between the two stud holes in the tail section inside 1647-xxxx i can tell you what you have with this number (last 4 numbers)
lower unit 1.87 gears
By stalk360 in forum Lower UnitsReplies: 0Last Post: 06-07-2016, 09:36 AM -
OMC Lower Unit Gears
By DaDolt in forum Lower UnitsReplies: 0Last Post: 12-01-2015, 02:13 PM -
PCM lower unit gears
By shesha in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 5Last Post: 07-17-2012, 11:10 PM -
Lower unit gears
By jody in forum Technical DiscussionReplies: 1Last Post: 09-01-2009, 11:58 AM
