Results 1 to 4 of 4
Thread: 99 Triton TR18
09-06-2021, 09:57 PM #15000 RPM
- Mar 2016
- cincinnati, ohio
- 664
- 143
- 32
- 279
- 191
99 Triton TR18
Picked up a 99 POS Triton TR18 bass boat today. She was involved in a hit and run and knocked the gelcoat off completely down to the fiberglass on the top, side of the boat by the casting platform. If all I want to do is patch it and place a sticker covering it up, what do I need to use to build up the surface?? Should I use epoxy or resin or gelcoat?? I figure gop it on and sand it smooth and cover it??? Thanks
09-08-2021, 09:53 AM #2Screaming And Flying!
- 14,753
- 381
- 1302
- 5601
- 11031
Depending on how much is ground away. If 1/4'' is missing then poly resin and glass. If it's just a 1/16''to 1/8'' and some rash then a thickened gelcote would suffice. Stay away from auto type fillers. They are not up to marine standards. Pics always help if available.
Will hedrick liked this post
09-08-2021, 02:19 PM #35000 RPM
- Mar 2016
- cincinnati, ohio
- 664
- 143
- 32
- 279
- 191
Sorry, not savvy enough to load pictures (love everybody else's tho). Yeah, it is probably only about 1/8th inch, just knocked the gelcoat off, will try gelcoat, thank you.
XstreamVking liked this post
09-09-2021, 04:48 PM #4
Thats solid advice. I would just add that if you're going to do gel remember to add some type of surfacing agent(wax, Duratech, etc.) so it will properly cure.
02 triton
By ericw in forum Hulls up to 20'Replies: 1Last Post: 08-18-2018, 03:11 PM -
31 Triton
By David in forum PropellersReplies: 5Last Post: 12-23-2016, 08:06 PM -
Triton set up
By Charliem7 in forum Props, Setup, and RiggingReplies: 9Last Post: 07-21-2016, 06:10 AM -
28p hoss triton i , 30p hoss triton ii, chopper 30p old, srx 29p and mazco re3 27p
By alexprime in forum PropellersReplies: 19Last Post: 06-17-2016, 03:12 PM -
new triton what now
By hook setter in forum Posting Questions and SuggestionsReplies: 1Last Post: 06-10-2007, 01:23 PM
