Results 1 to 3 of 3
09-06-2021, 02:34 PM #1
Mercury 2.0 1991 150 hp powerhead resurrection help
Due to bad luck and economics I have to use a power head that has not been on a boat since 2000. I liquidated the cowling, brackets, whole midsection including driveshaft plate and exhaust adapter plate. Along with the solid motor mounts. Now my problem is Im using my 1piece drive shaft plate with my 2.4 alien cowling plate. As pictures will show I know the exhaust is a bit smaller than the plate. I can deal with that. The problem is and I didn’t see it until the last minute is that at the bottom of the block where exhaust divider plate and cover is. Is that it sits roughly 1/4-3/8 lower than the block. It will not seal because of this and the stainless plate is not going to be forgiving enough. What are my alternatives. Besides having to get a used 2 piece plate new motor mounts etc. any thoughts would greatly be appreciated
09-07-2021, 05:25 AM #2
thats a normal deal with some.. ya gotta touch up tha cowl plate ta clear tha divider plate/bolts...........
09-10-2021, 11:39 AM #3
Thanks tlwjkw
1991 2.5 blown powerhead 200hp
By Summertop511 in forum Outboard EnginesReplies: 1Last Post: 06-14-2019, 12:13 AM -
Mercury Tech: 1991 2.4 Powerhead Swap Help
By MackDSM in forum Technical DiscussionReplies: 1Last Post: 02-26-2011, 07:44 AM
