Page 5 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 61 to 75 of 135
  1. #61
    Appleton,Wi.
    Wow this is great..Im still workung with Dann0 on the road thanks to everyone for stepping up..we as a boating community can get this done..I want give Gregg a special thax2 for supporting this because if wouldnt have started scream and fly none of us would be here..even when i started 20 years ago....Hazmatt out..
    Matt
    '89 Hydrostream Valero bowrider yt
    '83 Mariner Formula 200 prototype Experimental aircraft association fuel injectiion
    Hydrostream Owners Group
    North American On Plane Towing Association
  2. Likes LakeFever, wetsetmarine liked this post
  3. #62
    We need some project advice: Sanding is coming along well. Remember that we had to sand off the outer gel because an attempt was previously made to re-gel the top cap of the boat. The gel was on thick and was not smooth. I would imagine it is hard to get gel to lay smooth when not coming out of a mold.
    Well, we got most of it off and as we are progressing, we are starting to feel the original flake coming through in spots. You can feel it. We are concerned that if we keep sanding, we may go too far and make matters worse. So our question is, where do we go from here? Keep sanding, or is it best to get as flat as possible and then prime/sand/paint? Unfortunately, the guy who would be the go-to on this topic is no longer with us. So, solid advice is needed here, please.
  4. #63
    Jun 2018
    Floating around
    I’m in the same boat at a similar crossroads. I’d say it depends on how good a job your after. If your not super fussy hit it with surfacer and sand/repeat until happy with finish. If you want a really good job I’d strip all the gel off, repair any stress cracks and put one layer of csm over the entire exterior hull and roll waxed gel over that. Then cut that down until smooth ish and then gel with top coat.
    that’s my two path choices as of now and I’m going to lean on csm over the entire hull if I can.
  5. #64
    It's getting painted. We have a volunteer for that.
  6. Likes David - WI, Speed Jr. liked this post
  7. #65
    The problem with the finish is getting it ready for paint with metal flakes being in the surface. I would think it would be a bad idea to sand them completely out because A. gel is hard and fiberglass is relatively soft in comparison when sanding, and B. it will take 100 hours of work. On the other hand, not sure if we are going to be able to get the desired mirror finish without sanding a ton. The goal here is not a award winner, just a nice, decent looking boat.
    Thoughts on prep and suggested materials?
  8. #66
    Shawano,WI
    Have you decided on power yet? (Mercury/OMC) I think I have a key harness but its for a Merc.
  9. #67
    Jun 2018
    Floating around
    Quote Originally Posted by FlowMaxx View Post
    I see. Well if your painting and your comfortable with auto refinishing paint you can use spray putty as a surfacer and so long as you have a decent finish to the existing gel before hand it should cover enough to avoid print through, at least for a while. Then you can hit that with a good epoxy primer surfacer which is harder and that should seal it good and the top coat paint urethane base/clear will really pop and last. Getting pretty spendy on materials though... You could roll on gel with wax over the flake and cut it down to 180 grit and then hit that with epoxy primer too. That might be the cheapest way to go just a bit of work cutting down the gel. The spray putty cuts down FAST and fills really well.
    On the bottom of the hull your also going to paint or gel?
  10. #68
    Dec 2001
    Tisk Tisk......I know........Dave S. post......I remmber that Peat Delacker told me of an household ........wash/thing that would cut the faded coat and leave the flakes....... with out sanding......Thinking Ron Hill..... his freind may know.....Ted May might......
  11. #69
    Nick P stopped by tonight and dropped off some awesome stuff to help the project including some really nice rims and tires for the trailer, a red top battery, some wiring, switches and a kill switch. Thanks Nick for taking the time out of your day to deliver these awesome parts. The generosity thus far towards this project has been amazing.
  12. #70
    Quote Originally Posted by Forkin' Crazy View Post
    I wish I was closer.
    You can always donate Dans77vamp@gmail.com
  13. #71
    Stillwater MN
    I see a lot of people offering up stuff so unsure what's still needed. I have a variety of things I'd be happy to donate for this cause, or if just money needed I'd do that too. Let me know and I'll be prepared to hand off at FYNBAHR.
    "Under Promise -- Over Deliver"
    • 1991 HydroStream Voyager XT (Waterski Magazine 1991) 200 SHO
    • BB2003 (aka Ali-Shot) 3.0L OMC
    • 2003 Mirage Ski Racer -- 300 ProMax
    • G3 X22 RC Pontoon F115 Yamaha
    • Ercoa 16' Pontoon w/Mercury 25EFI 4-stroke
  14. Thanks FlowMaxx thanked for this post
  15. #72
    Quote Originally Posted by deCler View Post
    Pete - Good to hear from you! We are closing in on getting all of the major items covered including windscreens, interior, jackplate, steering, fuel tank, gauges, battery, trailer wheels etc. If you have something unique, special or nostalgic, that would be bonus. Otherwise, $$$ will help bring the finishing touches.
    That being said, we don't have our hands on everything yet and are relying on items to be picked up, delivered or shipped.
    Thanks much!!
  16. #73
    WI
    Thanks much!!
    Donations & parts already delivered aside, we have kept documentation of things that are said to be donated or are on the way so we don't have an exact account of things still needed. In the next week or so, we will get together a list of what isn't accounted for so anybody willing to send out those items ASAFP can do so. We REALLY APPRECIATE the UNBELIEVABLE support from everyone so far.... please note that this help has ONLY been published on this website because of the character of people that belong here & because of the help that this community always provides for their fellow friends!!!!!!!! I personally, & assuming I can speak for the rest of everyone involved in this endeavor, couldn't bring it to ourselves trying to get help from any other avenue! Thank you all again!!!
    I have a boat or two.... that I never get to drive
  17. Likes LakeFever liked this post
  18. #74
    WI
    This week we did a ton more sanding but also got the donated wheels & tires mounted to new hubs, bearings, and seals to help make this trailer trouble free!! Next is new wiring and lights
  19. #75
    Quote Originally Posted by PaulR View Post
    Yes, what motor... what condition... what does it need?
  1. Operation Vector commencing
    By hydroViper235 in forum Fiberglass and Composites Discussion
    Last Post: 05-27-2021, 08:48 PM
  2. Operation 115 tear down and 140-ize has begun
    By 71V153 in forum Technical Discussion
    Last Post: 03-31-2018, 08:54 PM
  3. operation repo
    By scc82 in forum General Boating Discussion
    Last Post: 08-08-2009, 07:00 PM
  4. Battery Switch Operation
    By cocacola in forum Electronics, Audio Systems, and Wiring
    Last Post: 05-28-2007, 08:27 AM
  5. Jackplate operation
    By Ac in forum General Boating Discussion
    Last Post: 05-14-2001, 12:19 PM
