Results 1 to 2 of 2
Thread: Crank
    Apr 2021
    Californian
    Crank
    I had a major issue this last weekend I had a water line break filling my housing full of water tell it filled the bottom cylinder and bending a rod. Does anyone have a crank for a 1996 Mariner magnum 175 HP I am concerned it compromised it because of the force it must of took to bend a rod. Or am I ok cylinder wall is good. I will probably replace all the rod bearings because of the water causing rust over night. Any thought or opinions would be great.
    Dec 2001
    1996 motor has week 141 rods.... prone to bending..... not like 5250s you prob ok........Put it on V blocks and spin....... Ck for center main run out. Or take to crank shop....... Down the street...............
  1. New Big bearing 2.5 crank (not a 260 style crank)
    By GILMORE010 in forum Misc. Parts and Accessories
    Last Post: 02-24-2016, 03:32 PM
  2. Replies: 29
    Last Post: 10-22-2009, 09:42 PM
  3. what is the difference from a 260 crank to a fishing motor crank
    By camaro7081 in forum Technical Discussion
    Last Post: 02-14-2007, 08:20 PM
  4. Top Main Crank Bearing/ Rod To Crank Bearings
    By mr twister in forum Technical Discussion
    Last Post: 09-09-2003, 08:45 AM
