Results 46 to 49 of 49
Thread: Taking a second look at omc
09-17-2021, 09:07 PM #46
09-17-2021, 11:01 PM #475000 RPM
- Sep 2008
- charlestown, ri
- 293
- 10
- 37
the v4 loopers were 10 lbs less than the 60 degree v6 motors. A v4 looper and a v6 crossflow were about the same weight, accept for the later ones which were about 30 lbs heavier than the V4.
09-18-2021, 08:38 PM #48
GT 200 fresh water motor out of lake Okachobee area, not sure of year but has white cowels with orange and black graffics, re built with a few grinds. just want to make sure it has all it's original parts re installed. going on a 18' donzi hull ( copy from the guys at scarab as a side project back in the day ) hull only as a center console as a sit down configuration w/foot throttle. heavy hull as it was intended to have BBC and outdrive, something for the snotty water that usually follows me wherever I go. 42 gallon tank in the foreward area to allow some exploreing without worrry of low fuel ( da Keys ). no high end runner but lively enough to at least keep them in sight til the water gets ugly thanks for your input as it seems like you have been there and done that Fun Out
most overnite successes usually take at least 10 years
Certified turd polisher,
Instigator liked this post
09-18-2021, 11:41 PM #495000 RPM
- Sep 2008
- charlestown, ri
- 293
- 10
- 37
there was probably some voltage on the black/yellow kill wire.
Taking apart a trim ram
By aggiestckl in forum Technical DiscussionReplies: 2Last Post: 04-16-2019, 08:56 AM -
Taking paint off cle.
By SkeeterD in forum Technical DiscussionReplies: 5Last Post: 01-28-2007, 04:28 PM -
Taking it to the next level
By mr.clean in forum General Boating DiscussionReplies: 13Last Post: 08-28-2006, 06:26 PM -
taking a 3 lt omc to 3.6
By charger19 in forum Technical DiscussionReplies: 2Last Post: 11-24-2001, 08:02 PM
