Results 16 to 22 of 22
09-03-2021, 03:50 PM #16
20 years ago a Boat like yours from Texas was the king of Lake Racer in ODBA he ran a Galen worked OMC,
the nice thing about your boat is If the motor cuts out or you back out quickly you won't HOOK like some boats
I tell you having a mechanic near by that you can trust is priceless, where you live boating season is too short so make the best of it, Kudos Captain.We have invented the world; WE see
09-06-2021, 03:44 PM #175000 RPM
- Mar 2009
- Houston, Tx
- 140
- 9
- 25
About the water. I have a 1993 V-21 and after I replaced the rub rail and replaced all the caulk it seemed to fix my water problem. I put caulk on every single rivet and used a good bit on the bottom side of the rub rail at the rear steps.
Jason H.
moatorbotin liked this post
11-20-2021, 02:34 PM #18
Michael J Giesler, moatorbotin liked this post
11-20-2021, 07:54 PM #19
Looks great!
Moatorboatin, glad to see you enjoying your finally found V21. I feel the same way about my 23 Eliminator Daytona.
Looks like you guys got a head start on winter so it’ll ready for spring.
Keep us posted on the progress.A problem is only a problem when viewed as a problem...
11-22-2021, 08:34 AM #205000 RPM
- Aug 2018
- MI
- 458
- 39
- 233
- 291
Should not be long and the motor will be wrapped up. @Capt.Insane-o is finishing up the final checks on the motor.
We will see how winter treats us, but I'd like to update the gauges, update the stereo, re-rig the bilge in a slightly cleaner easier to reach everything fashion......and the trailer could really use a hug. None of the remaining items once the motor is finished are 100% required to enjoy the boat, so we'll get to them at our leisure while enjoying it.
HydroSkreamin liked this post
11-22-2021, 10:05 AM #21Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,644
- 606
- 923
- 1698
- 7150
- 3 Post(s)
Sounds like you have acquired a boat that you will enjoy more then any of your past rigs. Looking forward to seeing complete and making you smile-
05-16-2022, 11:12 AM #225000 RPM
- Aug 2018
- MI
- 458
- 39
- 233
- 291
Little update: Had a ball last year with the 200 on the boat. Picked up the 280 over the winter and am back to the original fuel system. Would like to re-do my fuel lines and looking for suggestions. 'Original' rigging to my knowledge from previous owner. 1999 Triad w/1999 280. Current set up: Tank --> Water Separater - Pump (believe to be a bosch 984 or 044 style, can confirm if needed) - inline filter - fuel rail, return line from motor goes back to tank.
I read this 100 times: http://www.diamondmarine.com/web_pages/Fuel%20System.htm
At the very least I am looking for the following:
1. Recommendation for Water Seperator base part # - I think I have the 1/4" inlet (tank to seperater base) diamond mentions and would like to find a base that accepts the merc filters.
2. Fuel line recommendation?
3. Pump low in boat - mine is almost even with bottom of tank, can't get it too much lower, close enough?
4. Inline filter after the pump, from a packaging standpoint it would be a lot easier for me to put this in the cowl/pan instead of in the bilge the way it is rigged. Is there any reason I can not do this?
Lastly, can't tell what pump is used in this kit, but it appears to provide enough GPH and PSI - anyone tried grabbing a kit like this to make things easier? (not sure if that fuel line would be acceptable to use)
https://www.jegs.com/i/JEGS/555/15949/10002/-1?gclid=CjwKCAjw7IeUBhBbEiwADhiEMY6ZyYF1r005r5H-QZ0OupHrAT-Q6nQgMeru96utWptu9N4BA2o1xBoCcDAQAvD_BwE
Any and all suggestions appreciated.Last edited by moatorbotin; 05-16-2022 at 11:49 AM.
Barn find
By 25ss in forum Outboard and Racing HistoryReplies: 10Last Post: 10-05-2017, 11:44 AM -
barn find
By rock in forum General Boating DiscussionReplies: 21Last Post: 04-09-2017, 01:19 PM -
Barn Find
By vnemous in forum General Boating DiscussionReplies: 31Last Post: 09-22-2015, 07:19 PM -
Triad Barn Find
By Tague in forum General Boating DiscussionReplies: 75Last Post: 04-10-2014, 07:45 AM -
Barn find.
By Smoking Joe in forum Outboard and Racing HistoryReplies: 8Last Post: 12-16-2011, 03:55 PM
