Results 1 to 15 of 22
08-27-2021, 07:42 AM #15000 RPM
- Aug 2018
- MI
- 458
- 39
- 233
- 291
1999 Triad V-21 - build/barn find/set up
Recently picked up a 99 V-21. Thought I'd share where I'm at with it.
Backstory, I've wanted one of these since I was a teen ager and a friend on our lake had one. I looked for years, couldn't find one (or couldn't afford one).
In the meantime I didn't want to go boatless, so years ago I had a progression 24LD with a 300x, was a good fun 85 mph boat...unfortunately, divorce hit and the boat and I had to part ways. Fast forward a few years and I rejoined S&F and picked up a 2006 Vegas XT, the 2.5xs popped and work was uncertain, so I had to sell.
I then picked up a Sunsation 288 with a 600SCI in it, and to be honest, I never really liked the boat and wanted to get back into the outboard world.
I set out for a Progression 22 or 24LD, potentially another vegas, but really wanted a V21. I was able to stumble across this one in the V21 group on the face space.
It is a 1 owner boat that I'm told is a kevlar lay up. 1999 280 with 150 hours on it.
Per this thread: https://www.screamandfly.com/showthr...-to-these-days I didn't want to run the motor until someone who knew more than me (not hard to do) could inspect it and make sure it was in proper order, I expected it would at least need rings/bearings/etc.
It was recommended that I check out Capt. Insane-O who is only about 45 minutes away. So remembering the name from over a decade ago and seeing some of his previous builds I felt like I would be in good hands.
I pulled the powerhead and took it up to his shop a few weeks back. Upon pull down we found that the motor was just filled with carbon, rings were shot as expected (150 hours, never opened up). We were optimistic that everything else would look good, and for the most part it did.....until Lynn was able to clean the carbon out of the bores and found that the Nicasil had been compromised. The block has been prepped for a re-coat and parts have arrived. Injectors flowed and reeds sent out.
Now the waiting begins, at least once the block is back it should be able to be assembled fairly quickly.
In the meantime I wanted to get on the water and found a cheap boat with a 96 EFI FF block 2.5 that I went and picked up. (I still have the boat if someone wants it, otherwise I am going to pirate what's left for a hydrostream vixen that my son and I will finish restoring) that will be our first, and we know next to nothing, but we're interested in learning and spending that time together out in the barn.
<-- don't know why that one keeps rotating.
The Jackplate on the triad was trashed, looks like it had water in the system and froze, so upon recommendation from Chummy and the guys in the V21 group, we went with a 10" jack from Hydrodynamics.
<-- now they are all rotating for some reason?
I swapped the 200 onto the boat, bolted the sportmaster up and ran new fuel lines. I can't seem to get the water pressure gauge to read, the tach only works when it wants to, and I removed the plumbing for the tell tale speedo with plans to add a GPS speedo later......
So, the engine is still a little low, if the tach numbers I'm seeing are accurate, we're doing OK to start. I'm seeing (according to my phone) about 78 mph. 28 Lightning ET. Tach shows about 6800, i thought I read max RPM for the 200 EFI is 5800, do they have a rev limiter or is that just a suggestion?
I believe there is more in it with the 200, but not willing to push the engine height issue until I can get water pressure to register, though the temp guage seems to read well and is showing about 150. I confirmed in a pot of water that the thermostats do open, but forgot to use a thermometer to see what temp they are opening at. I assume 140.
Anyway, enough of the babbling, I'll raise the engine another click before the weekend and see where that puts us.
Enjoy the pics and please offer up any tips suggestions you may have.Last edited by moatorbotin; 08-27-2021 at 10:06 AM.
08-27-2021, 07:43 AM #25000 RPM
- Aug 2018
- MI
- 458
- 39
- 233
- 291
08-27-2021, 08:36 AM #3
Hold the phone in it's native orientation to take the photo. If you hold it upright you'll get a sideways photo.
tnelsmn liked this post
08-27-2021, 08:45 AM #45000 RPM
- Aug 2018
- MI
- 458
- 39
- 233
- 291
08-27-2021, 09:52 AM #5
Crank,rods and all other carbon covered parts came back from the dishwasher yesterday and look much much better. Injectors came back home.
The 200"s will pull past the limiter and stop at about that point. They are very good motors. I have a lot of 3cyl 49ci parts to send with the vixen so bring your truck.
moatorbotin liked this post
08-27-2021, 10:59 AM #65000 RPM
- Aug 2018
- MI
- 458
- 39
- 233
- 291
08-27-2021, 11:01 AM #75000 RPM
- Aug 2018
- MI
- 458
- 39
- 233
- 291
08-27-2021, 07:09 PM #8
You will love the boat. It handles great and runs on top of the water and is very forgiving. I found mine in a barn 4 years ago and restored it.
moatorbotin, Forkin' Crazy liked this post
08-27-2021, 08:52 PM #9
Sweet boat. Love the old barn finds.
2023 Progression 22 w/ 2015 Mercury 300XS. 2018 Kawasaki Ultra LX. 1969 Hustler Wildcat. Gone but not forgotten: 1991 POS GW Invader. 1976 Donzi Hornet II. 1994 Formula 232 LS. 2001 Regal 2660. 1990 Formula 206 LS. 1992 Checkmate Pulse 186 w/ 2003 Mercury 200 EFI. Random assortment of jet skis.
08-27-2021, 10:24 PM #105000 RPM
- Aug 2018
- MI
- 458
- 39
- 233
- 291
Put a bike pump to the water pressure hose and it blew off the back of the gauge and spit out a bunch of junk all over the front seats
after that we could blow in the tube and the gauge moves so hoping that works in the morning.
wired the control box so I could start in gear. (My 600 ate my upper gear set for lunch and the shop felt shifting really had taken its toll so I’m gun shy and wanna protect the lower).
re-measure and raised the engine. Chummy said go 1.5, I’m at 1.25 now and have one click left on the jack plate which would give me 1.5. So we’ll see how that goes tomorrow. Was at about 3/4” above bottom last time out.
08-27-2021, 10:26 PM #115000 RPM
- Aug 2018
- MI
- 458
- 39
- 233
- 291
CUDA, Capt.Insane-o liked this post
08-27-2021, 10:38 PM #12
Now was not that better than boxing it up and shipping to Texas
Your in good handsWe have invented the world; WE see
08-29-2021, 06:23 AM #135000 RPM
- Aug 2018
- MI
- 458
- 39
- 233
- 291
more convenient for sure. Met up with Capt crazy yesterday for a ride and hung out for the day. Had a great time.
1.25 was too high, couldn’t get much more than 10psi unless the motor was fully tucked, got a touch warm at speed, dropped it back down 2 clicks and we’re getting good water pressure again. Borrowed a 28 chopper from Capt that well try once we get a fat shaft hub into it. For the meantime its a 78 mph boat that well enjoy.
My son took a few passes himself as well. He’s starting to get the hang of balancing the boat.Last edited by moatorbotin; 08-29-2021 at 07:49 AM.
09-02-2021, 07:28 AM #145000 RPM
- Aug 2018
- MI
- 458
- 39
- 233
- 291
No major updates, but took the boat out again yesterday and can confirm @JBS is correct, I absolutely love this boat so far.
I was getting a random "cut out" where the motor would quit, I noticed when I was out with @Capt , that the voltage gauge would spike right before it happened. He quickly diagnosed that the voltage regulators were likely on their way out. Ordered up some new CDI units and took the boat out last night, tach now consistently works and never once had a spike in voltage or any motor quitting.
This boat also seems to take on a ton of water no matter how slowly I try to come off plane, I spun around one of the vents so the openings face forward, I also plugged all of the un-used rigging grommets that are on the boat. Still have a little space to bring water in on a couple of the grommets, but the amount of water we took on seemed much less.
Can it be coming in at the rub rail too? it sits with the rub rail just a few inches above the water, but the rub rail does go under on take off and slow down.
I also noticed the jackplate seems to scoop a ton of water when i come off plane, wondering if one of those jackplate skid plate deals would be beneficial?
Lastly, took a couple top end runs and hit 79.3 and 82.4. Pretty happy with that considering I had a full 30 gallons of fuel, my wife and I and lifejackets, dock lines, anchor, cooler, etc all in the boat. Still with the 28ET, RPM's around 65-6700, what kind of slip should be expected on this boat?
82.4/6700/1.87/28p=14%
tnelsmn, Capt.Insane-o liked this post
09-03-2021, 12:25 PM #15
I just came in from running mine and trying a new prop. It was a prop that came off a bass boat but ran surprisingly well. I would check around the rub rail to see if that's where the waters coming in? Once you get the 280 dialed in you should run triple digits. A few guys down here are running that consistently on their V21s.
Barn find
By 25ss in forum Outboard and Racing HistoryReplies: 10Last Post: 10-05-2017, 11:44 AM -
barn find
By rock in forum General Boating DiscussionReplies: 21Last Post: 04-09-2017, 01:19 PM -
Barn Find
By vnemous in forum General Boating DiscussionReplies: 31Last Post: 09-22-2015, 07:19 PM -
Triad Barn Find
By Tague in forum General Boating DiscussionReplies: 75Last Post: 04-10-2014, 07:45 AM -
Barn find.
By Smoking Joe in forum Outboard and Racing HistoryReplies: 8Last Post: 12-16-2011, 03:55 PM
