Results 1 to 5 of 5
    Aug 2021
    Sebring Florida
    MX 13 Clone, prop suggestions
    Putting a stock Merc 115 6cyl inline on an MX 13 clone. Looking for suggestions on first prop, I don't have one at all for this engine so no data. Thanks! -Eric
    Celina, Ohio
    How high is the motor on the transom? Are you just looking for all out speed?
    Aug 2021
    Sebring Florida
    Quote Originally Posted by largecar91 View Post
    Speed. I haven't mounted this new 115 yet. The 50 had 15" from bottom centerline of boat to skeg on engine. I can mount this a couple of inches higher, but not lower. Planning on using jacking plate so I don't have to remount to find the sweet spot. Probably hydraulic.
    EDIT: Doh, transom height. 20"
    =Eric
    Celina, Ohio
    I have run quite a few combos similar to this over the years. I've had 14', and a few 16 MX but never a 13. If your motor has ADI ign then it is the same as an early 150. If you have a low water pick even better. I would start with around a 26-28" inline chopper(3 blade). It will be a handful. As always make sure your steering is tight. A foot throttle and trim buttons on the wheel or foot rest or blinker so you can keep 2 hands on the wheel.
    Aug 2021
    Sebring Florida
    Many thank you. Looking at LWPs, pretty sure that's going before first run. Foot throttle is a must, left fingers are dead, I strap left hand on the wheel with a special glove, no way I can mix a hand throttle in the there.
  1. Prop Suggestions?
    By PaulO in forum Props, Setup, and Rigging
    Last Post: 05-24-2019, 04:23 PM
  2. In need of omc prop suggestions
    By Palmtreeguy in forum Props, Setup, and Rigging
    Last Post: 10-18-2015, 09:08 PM
  3. Prop suggestions
    By lastman in forum Props, Setup, and Rigging
    Last Post: 10-27-2010, 12:30 PM
  4. prop suggestions
    By pool boy in forum Props, Setup, and Rigging
    Last Post: 08-14-2009, 10:30 PM
  5. Prop Suggestions Please
    By mbrien in forum Props, Setup, and Rigging
    Last Post: 06-17-2007, 05:30 AM
