Results 1 to 6 of 6
    7 Post(s)
    OMC electrical issues
    My 89 Johnny 200 GT has been giving me a bit of grief lately.
    I thought it was a gas issues but turned out to be electrical.
    This is the third time this happens to me. I get to the launch and it wont start.
    Today, I got smart and tried to fire it up in the driveway before we left. Sure enough,
    no spark. I went through all the wiring and couldn't find anything. Moments later she fired right up and didn't give us any more problems the rest of the day.
    Again, this is the third time this happens.
    8 Post(s)
    cranking speed?
    Sep 2008
    charlestown, ri
    disconnect the black/yellow kill wire and check for spark. report back. we can walk you through this. cranking speed is the first step aka fresh battery that takes a good load. third step make sure all grounds, especially to the power pack are clean and tight.
  4. Likes powerabout liked this post
    7 Post(s)
    Well I didn't disconnect the black/yellow wire. I turned the key and she fired right up with out gas or primer. I'm starting to think it's a kill switch wire somewhere. I noticed another kill switch under the gear shifter shaft. I wonder if that's the culprit. If it gets cooler, I will play around with it this week after work.
    Thanks for the help people.
    May 2001
    Hickory NC
    Once started if it runs ok doubtful its the kill switch. Most over look crank speed as if only off a few rpm will not have spark.
  7. Likes z1rider liked this post
    7 Post(s)
    As the battery weakens from trying to start it, I should not be able to start it, but each time this happened, I made it out anyway.
    It's been too hot for me to work on it after work. Gonna play with it on the weekend.
  1. 3 cylinder evinrude 25 hp electrical issues?
    By oldschoolltv in forum Technical Discussion
    Last Post: 01-01-2019, 03:38 PM
  2. Mercury Tech: 200 EFI Electrical Help
    By tmanala in forum Technical Discussion
    Last Post: 07-17-2014, 10:41 AM
  3. Need electrical help...
    By Jaguar2000 in forum Technical Discussion
    Last Post: 09-27-2009, 10:48 AM
  4. 2.5 EFI SS electrical issues
    By Toffen in forum Technical Discussion
    Last Post: 07-15-2006, 11:38 PM
  5. 94 xri what do i not need electrical
    By 25 martini in forum Technical Discussion
    Last Post: 06-03-2003, 05:53 PM
