Results 1 to 7 of 7
08-16-2021, 11:30 AM #1
aeromotive fuel pressure regulator issues?
Anyone have an aeromotive fuel pressure regulator not hold pressure? I have 56 lbs at idle, drops to 52 lbs when you rev it up.
Brand new Bosch 044 pump. Laser efi set up with return line back to fuel tank.Allison XB02, 22ft Tritoon 225 4 stroke, two seadoo sparks
Past rides 2001 STV EURO, Allison Grandsport, STV RiverRocket, STV Euro, STV ProComp, Hydrostream V-King
RIP RPM RACING
RIP GTS1
08-16-2021, 11:33 AM #2
Is it the aero motive regulator for EFI motors? And if so is it getting the proper vacuum to the vacuum hook up?
08-16-2021, 11:48 AM #3
yes, not sure how I'd check the vacuum
RIP RPM RACING
RIP GTS1
08-16-2021, 12:16 PM #4
Usually when the fuel pressure drops its one of the following. Improper Vacuum, Fuel Pump going bad, Compromised or clogged fuel filter thats starving the Injectors.
08-16-2021, 12:22 PM #5
08-16-2021, 01:07 PM #6
Not sure but battery has 2 rides on it ie brand new as is the fuel filter, regulator, hoses etc, all new rigging
Question is basically just to see if anyones had any issues with a new aeromotive regulator, likely its not the issueLast edited by ProComp; 08-16-2021 at 01:10 PM.
RIP RPM RACING
RIP GTS1
08-16-2021, 01:36 PM #7Bud Conner "Heathen" "Defending Our Constitution"
David - WI liked this post
