Results 1 to 15 of 20
08-16-2021, 09:19 AM #1Junior Member
- Sep 2020
- wis
- 11
18ft Laser ltv 150 black max 60 mph???
I'm running a 26 chopper at 6000. Is this in the ballpark for mph? Was running 64, I added a torque tamer and tried regular instead of premium. Can't believe that would take away 4mph!
08-16-2021, 09:36 AM #2
Welcome to the site. Formula is RPM x gear ratio x pitch x .0009469. Assuming 2:1 gear and 15% slip you get 63 mph. Different gear ratio and different slip of course different results.
RockTeam Junk
groovy liked this post
08-16-2021, 11:49 AM #3Junior Member
- Sep 2020
- wis
- 11
Thanks, I've seen a couple different formulas for the rpm x pitch. So I guess I'm close to where I'm supposed to be.
Still don't understand where I lost that four mph. Going to run premium next time out and see what happens. Ultimately
I'm going to put some more hp back there.
08-16-2021, 12:36 PM #4
From spring air to summer humid air will require different jetting for maximum performance. Just going from premium to regular 4 mph sounds like a lot.
RockTeam Junk
08-16-2021, 02:41 PM #5Junior Member
- Sep 2020
- wis
- 11
Pretty much same conditions as far as air and water. Only other change was the torque tamer.
08-18-2021, 07:44 AM #65000 RPM
- Dec 2019
- Spring Lake MI
- 497
- 38
- 155
- 450
Torque tamer could slow it a bit too.
TJ @ Baker Engineering
Tuff 24 300xs
Tuff 16 90 Yammie
3.75@199mph with LSX power!!!
08-18-2021, 08:59 AM #7Junior Member
- Sep 2020
- wis
- 11
I wondered about that. I wouldn't think 4mph though!!
08-19-2021, 07:03 PM #8Junior Member
- Sep 2020
- wis
- 11
Took it out today, drained the regular and ran premium. 60mph at 5800-5900.
Did squeek 61 once. So I guess take the torque tamer off and try again!!
08-19-2021, 09:17 PM #9
91 Seaswirl 178 spyder sport. Evinrude XP175. (59 MPH, so far, and so close).
85 Sleekcraft SST , 225 Johnson...(sold)
Baker343 thanked for this post
08-19-2021, 10:15 PM #106000 RPM
- May 2001
- Madison, WI
- 1,147
- 253
- 39
- 499
- 198
Groovy... I sent you a PM
08-20-2021, 07:09 AM #11Junior Member
- Sep 2020
- wis
- 11
Can't figure out how to reply!!
08-30-2021, 09:21 AM #12Junior Member
- Sep 2020
- wis
- 11
Took it out with the torque tamer removed. Didn't really gain much if any! So I don't know where the 4mph went. I'm using the same gps as I was before so I guess it is what it is. Sucks though!! Lol. Anybody know what this rig should weigh? Tried a search and didn't find anything. Thanks
08-30-2021, 09:27 AM #13Junior Member
- Sep 2020
- wis
- 11
I came up with 925 dry so far.
08-30-2021, 09:31 AM #14
On mine a head gasket was leaking water into the cylinder. Compression tests didn't show any problem so I kept running it... trying to figure it out where the 4 mph went like you are... until is seized up.
08-30-2021, 09:38 AM #15Junior Member
- Sep 2020
- wis
- 11
Hope that isn't the problem. Didn't the water show up when you did a compression test?
1989 LTV Laser 18ft tunnel hull
By Ron M in forum Hulls up to 20'Replies: 2Last Post: 04-17-2018, 04:17 PM -
18ft laser ltv rigging and prop help
By carlp in forum Props, Setup, and RiggingReplies: 4Last Post: 06-27-2012, 04:49 PM -
18ft checkmate ???
By Z71_SS in forum General Boating DiscussionReplies: 15Last Post: 09-26-2005, 11:46 AM
