Results 1 to 3 of 3
Thread: 115hp Optimax coil advice
08-15-2021, 06:34 AM #1Member
- Oct 2018
- New Jersey
- 53
Hello all,
My coil just fried itself. Smoked for a second and Yellowish stuff oozed out of plastic (i guess where is cracked). Question is should all 3 coils be replaced or just the defective one? Not sure if the other are not far behind from failing or if this should be viewed as an isolated case.
08-15-2021, 07:40 AM #2Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Get new ones
08-15-2021, 07:55 PM #35000 RPM
- Sep 2017
- ontario
- 717
- 68
- 43
- 73
- 171
I second the above advice - I just recently sent an ECM to Simon to fix a driver on #6 . Cause was a coil . When I hooked it up to the DDT it showed a misfire on #6 - I believe 116 times .
It was suggested replace all coils from a solid tech- Ted at Speedmaster Marine .
Dan at Simon stated the same . Yes coils are expensive and so is sending the ECM out to get repaired - then buying coils .
Be glad you only need 3
XstreamVking liked this post
2013 optimax 115hp Pro xs
By 16blueboat in forum Outboard EnginesReplies: 2Last Post: 10-16-2016, 12:33 PM -
2007 115hp Optimax Longevity
By champ201 in forum Technical DiscussionReplies: 4Last Post: 11-02-2012, 06:31 AM -
Mercury Optimax 75hp -->115hp
By Optimax75 in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 9Last Post: 02-18-2011, 12:54 PM -
Mercury Optimax 75hp-->115hp
By Optimax75 in forum Technical DiscussionReplies: 0Last Post: 08-24-2009, 03:15 PM -
Optimax coil gone a second time!
By Carlson150XS in forum Technical DiscussionReplies: 7Last Post: 04-04-2005, 10:59 PM
