Results 1 to 3 of 3
    Oct 2018
    New Jersey
    115hp Optimax coil advice
    Hello all,
    My coil just fried itself. Smoked for a second and Yellowish stuff oozed out of plastic (i guess where is cracked). Question is should all 3 coils be replaced or just the defective one? Not sure if the other are not far behind from failing or if this should be viewed as an isolated case.
    Get new ones
    Sep 2017
    ontario
    I second the above advice - I just recently sent an ECM to Simon to fix a driver on #6 . Cause was a coil . When I hooked it up to the DDT it showed a misfire on #6 - I believe 116 times .
    It was suggested replace all coils from a solid tech- Ted at Speedmaster Marine .
    Dan at Simon stated the same . Yes coils are expensive and so is sending the ECM out to get repaired - then buying coils .
    Be glad you only need 3
  4. Likes XstreamVking liked this post
  1. 2013 optimax 115hp Pro xs
    By 16blueboat in forum Outboard Engines
    Last Post: 10-16-2016, 12:33 PM
  2. 2007 115hp Optimax Longevity
    By champ201 in forum Technical Discussion
    Last Post: 11-02-2012, 06:31 AM
  3. Mercury Optimax 75hp -->115hp
    By Optimax75 in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 02-18-2011, 12:54 PM
  4. Mercury Optimax 75hp-->115hp
    By Optimax75 in forum Technical Discussion
    Last Post: 08-24-2009, 03:15 PM
  5. Optimax coil gone a second time!
    By Carlson150XS in forum Technical Discussion
    Last Post: 04-04-2005, 10:59 PM
