Results 1 to 15 of 15
    Mar 2021
    Mb
    Charger 18dl 150 efi mercury hydraulic lift, Prop choices
    I use the boat for skiing and running around. Does 57 with Yamaha 13 3/4 x 21 black stainless semi- clever at 5900-6000, not a great deal bow lift at start. Currently running Yamaha 14 1/2 x 23 pro stainless with rectangular factory holes. Does 59-60 at 5600. Comes out close to as well as the smaller prop,a bit more bow lift, but does cavitate just as bit as boat plains. I was thinking of closing holes, but not my prop. With the 23 goes 2-3 faster at any given rpm. Any nerd props that would perform better? Open to suggestions.
    Gravenhurst, Ontario.
    That boat likes big ear, chopper style props for running top end stuff.
    My 18DL / 2.4-200 combo ran 80 @ 6000 +\- with a 28 merc chopper.
    I’ve got a few 24”-26” options you can try.
    Mar 2021
    Mb
    Went out yesterday. Ran the 23 prop, made 61-62 on gps reving 5500-5700. Have jack plate raised up 1 inch at time till gained rpm but lost speed. so tat is all I’m going to get. Still comes out of hole great. I think this is best she will do, not sure how some guys are getting 60 plus running 115 hp.
    Jun 2018
    Floating around
    It’s all in the set up. I’ve got a 75hp that’s almost at 60 now. Started in the low 40’s lol
    Lake Coochiching, Ontario
    What is the rev limiter set at on the 150 EFI? You may be on it
    Mar 2021
    Mb
    Don’t know, I’ve spun up to 6000 with a 21
    Mar 2021
    Mb
    What boat, rpm prop. Definitely not on a 18dl lol.
    Jun 2018
    Floating around
    Its small, its a 14' Vandal with a 24p small ear chopper thats had some work done to it. I mentioned it because it was a slug and I bought another motor to rig on it but started playing with the set up and the thing came alive. Its pretty exciting considering its dancing all over the place now its the rubber mounts that are limiting it not the power. I did not think it would go nearly as well as it does now. worked the set up, got results
    Try a 24” Merc chopper.
    should get you close to 6k and should carry the nose well.
    Oakville, ON
    I've got an 18SK that had a 150 XR2 on it until last year and it skied well with an old QS 23 Laser #48-11074A40. Good hole shot, holds well in turns and responds very well to trim. About 58 MPH I think with the engine on the transom but that's with a bow tank, so the DL should beat that. I tried the smaller diameter Vengeance but it didn't hook up as well.
    Mar 2021
    Mb
    Looking for Yamaha painted stainless 13 3/4 x 23 do they make such a prop. Have one that is 21, works great, not too much bow lift except revs to 6000 at 56mph. Tried a pro series 14 1/2 x 23, works well 61 mph at 5600. Only problem is have to run motor trimmed down at cruising speeds otherwise it will porpoise, this does not happen with the black stainless. Yamaha says pro series is great for bow lift, I don’t need have hydraulic lift with 6” setback.
  12. #12
    Sep 2006
    Dl doesn't like a cleaver
  13. #13
    Aug 2010
    Barrie, Ontario, Canada
    have you tried a 24p or 26p ET prop
    Triad V21 #002 - 15in DBR 300 xs
    19' J-Craft - 175 Opti
    18' Pontoon - 115 CT 4S
  14. #14
    Mar 2021
    Mb
    Quote Originally Posted by coffeeguy View Post
    What doesn’t it like abbot a cleaver prop?
  15. #15
    Sep 2006
    Needed way to much trim to carry nose and was 15+ mph slow at the same rpm
  1. Charger 18DL Stiff Steering
    By Sawbladz in forum Technical Discussion
    Last Post: 05-25-2020, 09:34 PM
  2. Bow lift or stern lift for Charger STV Mod Vee?
    By Mhoward in forum Props, Setup, and Rigging
    Last Post: 03-29-2014, 04:11 PM
  3. 18DL Charger Fiberglass Windshield Build
    By Murph in forum Fiberglass and Composites Discussion
    Last Post: 03-08-2014, 09:35 AM
  4. better of these prop choices?
    By zduckdogs in forum Props, Setup, and Rigging
    Last Post: 09-09-2009, 07:09 AM
