Results 1 to 3 of 3
    SW Florida
    1988 Chris Craft Stinger 313 - Twin 2004 225 Evinrudes - Rolls Trip Axle Alum Trailer
ID:	491638Click image for larger version.
ID:	491639Click image for larger version.
ID:	491640Click image for larger version.
ID:	491641Click image for larger version.
ID:	491642Click image for larger version.
ID:	491643Click image for larger version.
ID:	491644Click image for larger version.
ID:	491645Click image for larger version.
ID:	491646Click image for larger version.
ID:	491647Click image for larger version.
    Asking 15k.
    SOLD
    I purchased in 2013 and have a spreadsheet of every nut and bolt spent on it. Over 30k invested. Since 2013 just about everything has been replaced or redone. It's not mint but its a nice boat that you don't have to worry about putting a scratch in and looks 5 years old from 5' away. Interior is in excellent condition all removable and always kept indoors. Bimini and console cover is about 6 yrs old but still in great shape. Was always removed for winter. All original gel coat. Still shiny but it is a 1988 there are dock scuffs and scratches. Thin striping was redone with vinyl. The boat is well built and can take anything a rough bay can throw at it and rides smooth. 24 degree deadrise, same bottom as all offshore race boats. No stuctural stress cracks, transom and stringers are solid, wood is probably moist but it really doesn't matter these boats were built thick. I wouldn’t go out and jump swells in the ocean at 50 mph but I’m confident this boat is seaworthy and structurally sound and does fine in the ocean. These hulls weighed about 4600 according to factory spec. I once weighed it on a truck scale an it was 7600 loaded and ready for water with 90 gals of fuel. You need a good HD truck to tow it.
    Boat - 31 ft. 6" length. 8 ft. Beam. 24 deadrise. Center console with aluminum radar arch, bimini top, forward cabin. Removable bench back seat, two coolers under seat. Leaning post with removable cushion. Upholstered seat in front of console with built in fish tackle box/drawers under back rest and storage inside console and under seat. Two forward jump seats with fully removable upholstery and storage under. Cabin has bed cushions, mirror with storage behind it all the way forward, lighting, fully carpeted, porta potty, lighter and USB charging ports, cup holders. Faria gauges, Sea Star tilt steering helm, glove box, built in cup holders, new Stereo with bluetooth, Pandora, Spotify, Alexa. 4 Jensen Speakers, Lowrance Elite 5 Depth/Fish/Navigation, VHF. Everything was rewired, re-rigged in 2013/2014. Two optima blue top batteries, dual switch setup, two Rule 1500 auto water sensing bilge pumps. On board built in battery trickle charger. T type swim ladder that slides in to transom mount.
    190 gallon single fuel tank.
    Racor filters/water separators in line.
    Two built in bait wells one with bubbler, two in floor fish wells smaller one with bubbler.
    13 pole holders plus in gunwale side pole holders on both sides and forward sliding door storage on each side in gunwales.
    Stainless Marine engine bracket.
    Sea Star tilt helm with dual ram front mount Sea Star Pro Hydraulic steering.
    Engines:
    2004 Evinrude 225 DFI (direct fuel injection) two stroke. Very fuel efficient.
    Serviced August 2020 at 810 hours (Etec spark plugs, water pumps, all fuel filters), . Estimate that I used about 8 hours this season so far. Boat comes with an old laptop with software that can monitor engines and fault codes and print reports. Gear oil changed toward the end of season last year and again beginning of season this year. I change gear oil at least twice a year. Engines run great and push this boat to 53 to 55 mph regardless of load it will always do at least 53. 2.5 gallon Oil injection tanks have above deck fill caps. Counter rotating lower units. OMC Viper 18 pitch stainless props. I can send maintenance record log upon request.
    Trailer:
    Rolls Triple Axle aluminum float on trailer. New planetary gear type winch last year, new bunk carpet two summers ago, 6 new tires 3 years ago. Bearings have bearing buddies all bearings were replaced 2014. Surge brakes, new pads end of last summer. Led lights, all working and wired with shrink tubing. Guide poles.
    Boat is in water in Little Egg Harbor NJ and can be taken for test ride.
    2004 Hydra-Sports Vector 2600 - twin 225 Yamahas
    Oct 2010
    McAlester, OK
    I am liking this Stinger. The Trump flag alone makes me want to buy it!!!
    SW Florida
    SOLD now time to find me a Pantera!
  4. Likes larslindroth liked this post
  1. 23ft Chris Craft Scorpion 230 on Tandem Axle Trailer
    By mwe14 in forum Hulls larger than 20'
    Last Post: 05-07-2016, 10:21 AM
  2. Chris Craft Stinger with an outboard
    By slowmover in forum General Boating Discussion
    Last Post: 06-14-2011, 04:50 PM
  3. help with chris craft Stinger
    By Hottrucks in forum The Scream And Fly Lounge
    Last Post: 10-08-2008, 10:56 AM
