Results 1 to 2 of 2
Thread: Mercury prop hub. Help me
08-08-2021, 03:01 PM #15000 RPM
- Jul 2004
- DFW TX
- 111
I have a Lightning ET that has a plastic hub pressed into the hub. It is not flo-torque and the drive sleeve is a little one 23p856163Q1. The opening at the top is only 1 1/4" and fit my standard shaft just fine. Since the opening for the drive Aft adapter is the same size as the opening I don't think I can get an aft adapter that will fit the fat shaft.
I want to sell this for use on a fat shaft.
What is this kind of hub called?
Can a different hub be put in this prop to make it a flo torque or can this hub be removed so a flo torque can be installed?1999 Allison xb2003 2001 200XS
2000 Dodge diesel
08-09-2021, 10:34 AM #2
Old circle bore = pressed in rubber hub
Flo Torq is square bore, can have plastic hub kits or the heavy duty solid steel, no way to change a circle bore to a Flo Torq.
The picture you posted is a bushing from a plastic Flo Torq kit- 835257K 6. If that's what is in your prop, you have a Flo Torq hub.
If you have a circle bore hub, there is not a press-in rubber hub adapter for fat shaft.2000 Triad Mod VP 280 ROS
Will a Mercury Prop fit on an OMC?
By capt911 in forum Props, Setup, and RiggingReplies: 2Last Post: 09-15-2018, 06:10 AM -
WHAT ARE MY PROP WORTH ? Mercury 15x28 L and R Also Mercury 15x32 L and R
By Blackhillsoutdoor in forum Propellers WantedReplies: 11Last Post: 05-25-2017, 09:47 PM -
1978 Inline 6 Mercury Prop fit a 1986 Mercury 2.4 175?
By WSJR1 in forum Technical DiscussionReplies: 17Last Post: 07-31-2010, 03:51 PM -
Mercury 250 EFI prop
By SpeedCrazy05 in forum Technical DiscussionReplies: 20Last Post: 08-05-2009, 10:52 AM -
50 HP Mercury-10' boat -- Request boat tuning and prop advice + prop purchase
By Cedarwillly in forum Props, Setup, and RiggingReplies: 5Last Post: 09-03-2007, 01:05 PM
