Results 1 to 7 of 7
08-05-2021, 08:54 AM #1Member
- May 2021
- Florida
- 55
2002 xr6 150 wiring diagram needed
Does anyone know where I can get a copy of the wiring diagram for my 2002 xr6, serial is ot579827. Trying to figure out hot horn hook up. This year has cdi ignition, not switch boxes. Not sure if if make a difference for hot horn.
08-05-2021, 01:19 PM #2
Should be it?
08-05-2021, 01:28 PM #3Member
- May 2021
- Florida
- 55
08-05-2021, 01:49 PM #4
This one has an xr6 in it but don't know what year!
08-05-2021, 07:43 PM #5Member
- May 2021
- Florida
- 55
Thank you for the response. I’ll check it out no between the two I should be able to figure it out. Tx
08-06-2021, 01:46 AM #6
tha over heat circuit, alarm, sensor is tha same on all of 'em.... 2.0, 2.4, 2.5 carb, efi, switch box or 'lectronic......
08-07-2021, 01:16 PM #7Member
- May 2021
- Florida
- 55
ThAnks for the reply!
xb2002 wiring diagram help needed
By speedy in forum Technical DiscussionReplies: 3Last Post: 09-04-2018, 07:03 PM -
wiring diagram for 7 pin cannon connector at motor//wiring to start on engine stand
By seabold in forum Technical DiscussionReplies: 9Last Post: 10-24-2013, 08:50 PM -
200 - 2.5 CDM wiring diagram?
By malexie in forum Technical DiscussionReplies: 2Last Post: 06-24-2010, 12:04 PM -
By Bassman in forum Technical DiscussionReplies: 0Last Post: 05-01-2006, 08:33 PM
