Results 1 to 8 of 8
08-04-2021, 09:10 AM #1
1995 Merc 2.5 200 XRi dead spot in power
Noticed around 4k rpms my motor has a dead spot in power, takes about 2'' more pedal (hot foot) to over come the dead spot then it has a surge of power and pulls hard. The motor starts, idles and comes out of the hole fine it's just that 4k dead spot. It doesn't lose power just acts like it won't rev more until you give more pedal. Had a guy on a facebook page say he has the exact same motor with the same problem and his ended up being weak magnets in the flywheel. Said after replacing with a used one his problem went away. Just curious if anyone here had any advice. Thanks
08-05-2021, 08:26 PM #2
so are you sayin that at half throttle you get to 4000 and nothing happens for the next half of the throttle till basically its floored,then the revs increase?
08-06-2021, 07:18 AM #3
08-06-2021, 07:32 AM #4Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
Dead spot in the TPS,Meter it out through the full range,They tend to fail at the rpm they are run the most...
sam hain thanked for this postDavid - WI liked this post
08-06-2021, 07:34 AM #5
08-06-2021, 09:41 AM #6
Replace TPS and set it at .25 volts.
RockTeam Junk
08-06-2021, 10:19 AM #7
Wow that thing is $650
08-06-2021, 12:58 PM #8Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
Ohm test it before you replace it...
Mid range dead spot
By Merc 2.5 in forum Technical DiscussionReplies: 4Last Post: 05-08-2020, 07:41 AM -
1995 merc 3.0 225 efi rough idle and power loss
By Seanj85 in forum Technical DiscussionReplies: 7Last Post: 08-30-2017, 09:30 PM -
Mercury Tech: 2.0 135 Black Max dead spot / missing cylinder
By RoyE in forum Technical DiscussionReplies: 4Last Post: 08-11-2015, 03:11 AM -
dead spot in throttle on mercury 200hp 2.5c
By mouse4x4 in forum Technical DiscussionReplies: 8Last Post: 10-21-2013, 08:22 PM -
Dead spot Mercury 200 XRI
By 205pro in forum Technical DiscussionReplies: 0Last Post: 08-13-2010, 12:42 PM
