Results 1 to 8 of 8
Thread: Merc lightweight flywheel timing
08-03-2021, 06:19 AM #1
Can anyone share with me their method for setting timing with a flywheel that has no marks? Im assuming i need to use a 360 degree dial as well as TDC indicator but id like to have some specific instructions so i dont screw this up. Thanks!
08-03-2021, 07:49 AM #2
there are lots of posts on this site for this and many other questions. Here is an easy way to search scream and fly in google. just type in your question, or what you are looking for and in the end put "screamandfly.com" Google will search for your words and pull what it finds out of scream and fly! a link below but just google below and you will find more than enough posts to figure it out.
flywheel marks for timing "screamandfly.com"
flywheel indexing "screamandfly.com"
https://www.screamandfly.com/showthr...arks&p=3270528Last edited by rjdubiel; 08-03-2021 at 08:03 AM.
1973 Viper - sold
1978 Viking - sold
1995 XB02
Smalltownbassin liked this post
08-03-2021, 09:06 PM #3
TDC FINDER THEN CUT A TINY MARK IN IT.. then like you already said a 360 degree wheel or a piece of paper with 360 degree will let you mark it for what you want... being lightened wont make any difference . TDC is TDC
08-05-2021, 07:22 AM #4
08-05-2021, 07:26 AM #5
I read an archive that said turn flywheel clockwise to TDC, mark wheel at pointer and zero dial, then turn wheel counterclockwise 0.150 on the dial and mark wheel at pointer. This should be 25 degrees advance. That sound right?
25two.stroke liked this post
08-07-2021, 06:58 AM #65000 RPM
- Jun 2014
- United States
- 147
- 29
- 40
Yes, you are correct
Smalltownbassin, rgsauger liked this post
08-08-2021, 12:11 AM #7
Yep
08-10-2021, 11:36 PM #8
Setting timing using a 16 amp lightweight flywheel with no timing marks
By jdewaard in forum Technical DiscussionReplies: 19Last Post: 09-09-2015, 07:56 PM
