Results 16 to 26 of 26
Thread: Mariner 175 efi Prop help
08-06-2021, 08:21 PM #165000 RPM
- Jul 2021
- Pompano Beach
- 144
- 16
- 38
I sometimes go to Everglades City to fish for a few days, not sure if that's still too much of a hike for you. Thinking about selling the Tempest + when my new prop comes, it's not enough prop for me, and I'm going to a 25"Bravo XS. At 6000 rpms, I get 63 mph, 5500 rpms I get around 56 mph.......
08-07-2021, 06:55 AM #17Junior Member
- Jul 2021
- Pinellas
- 12
Update***
Tempest 21p came in early so I tool her to the lake yesterday evening.
Hole shot: Ok, not terribly impressive like the solas 19p. Might need to take the plastic plugs out of the vents and re-test.
Wot: 5500 rpm, 52mph.
Note when I took it out of the water the lower unit was warm to the touch...not sure if this is normal, never tried feeling before after running.
08-07-2021, 09:21 AM #185000 RPM
- Sep 2019
- Lake Keowee, SC
- 243
- 25
- 62
Removing the plugs should help it get on the plane faster. Due to the large diameter, the Tempest may run better a bit higher. Try raising the engine by one hole on the transom if you wish. That would typically help the top speed more than getting it out of the hole. WOT rpms were good. I think the Tempest is slightly larger diameter than the HR3 Solas. Lower pitch typically always comes out of the hole better but depends on prop design. The easiest thing to do is remove the vents like you said and try again. After that, you could have the 19P Solas modified by adding more cup height. That will reduce the rpm some and also reduce the slip. If removing the vents helps, you could also raise the engine one hole with the Tempest and try again. You could also get the Tempest modified to spool up faster and help the holeshot if you want to spend the money on it.
08-07-2021, 09:25 AM #19Junior Member
- Jul 2021
- Pinellas
- 12
David - WI liked this post
08-07-2021, 09:29 AM #205000 RPM
- Sep 2019
- Lake Keowee, SC
- 243
- 25
- 62
That's great if you have hydraulic jack plate. You can lower it to come out of the hole better, especially when the vent plugs are out, and then you can raise it slowly to increase the top speed. Run it lower to get on the plane and once you are at WOT and top speed, slowly keep bumping the jack plate switch up and watch the speedo. The speed should increase, and then at some point it will not increase, but the rpm will increase, and if you keep doing it eventually the both the speed and rpm will increase but I'm sure you have already tried that. The main thing is the two props might be more efficient at different jack plate heights.
Jbone86 thanked for this post
08-07-2021, 09:32 AM #21Junior Member
- Jul 2021
- Pinellas
- 12
Awesome, will try next time out
08-08-2021, 10:55 AM #225000 RPM
- Sep 2019
- Lake Keowee, SC
- 243
- 25
- 62
I made an error above. If you keep raising the plate, eventually the rpm increases and not the speed, and then the speed begins to drop as the rpm goes up but you already know that.
08-09-2021, 07:21 PM #23Junior Member
- Jul 2021
- Pinellas
- 12
Update*
Took the plugs out of the vents from the Tempest. Much Much better hole shot, you can really tell it spools up then bites and boom I'm on plane. Such a fun journey here. Next issue is hard starting and doesn't want to stay idling. After running for a bit it starts right up and idles fine. I'm sure that's a topic for another discussion board but figured I'd mention.
Thanks all for the helpful advise.
* going to try ccms performance reeds and stuffer kit then update after
08-14-2021, 11:36 PM #245000 RPM
- Jul 2021
- Pompano Beach
- 144
- 16
- 38
The tempest likes the jackplate buried in the mid range on my boat for best speed.
08-15-2021, 12:19 AM #25Junior Member
- Jul 2021
- Pinellas
- 12
08-15-2021, 09:40 AM #265000 RPM
- Sep 2019
- Lake Keowee, SC
- 243
- 25
- 62
Every boat and prop is different. Some boats have 19", 20" or 21" transom heights from the factory so a 20" shaft engine is low or high, even when it is right down on the transom. Some jack plates are installed low or high on the transom in addition to this. Many 4 blade stainless props have to be run higher to gain speed, and will run higher before they slip. If you have more setback on the jack plate you can usually run the engine higher. Most fast boats (not all) will handle better with less chine walk if the engine is jacked higher, but there are exceptions. The last two posts appear to be from individuals that have played with engine height / prop combos and found what is ideal for their boat.
Javelin 389 mariner 2.5l prop suggestions
By Javalin389boy in forum Bass Boats and Sport Fishing RigsReplies: 6Last Post: 04-14-2020, 11:01 AM -
Mercury and Mariner Prop covers
By thunter764 in forum Misc. Parts and AccessoriesReplies: 24Last Post: 11-26-2019, 10:32 AM -
Picking the right prop fro Mariner 200
By Texas in forum Technical DiscussionReplies: 3Last Post: 01-11-2008, 09:27 PM -
Need help to find right prop for 1989 Mariner 200
By Texas in forum Props, Setup, and RiggingReplies: 5Last Post: 09-17-2007, 06:04 PM -
87 Hydrostream Vegas w/ 175 Mariner-Prop?
By rubberman in forum Props, Setup, and RiggingReplies: 6Last Post: 08-25-2003, 12:35 PM
