Results 1 to 6 of 6
08-01-2021, 02:16 PM #16000 RPM
- Aug 2015
- Southeast
- 1,070
- 134
- 80
- 48
- 615
Cylinder head temp sender water temp gauge?
Any insight into what sort of reading to expect? I'm seeing 210 on the water temp guage using the regular temp sender thats on the cylinder head. Not in a water jacket.
Think that reading is way off. Certainly hope so. I'll get a regular temp gauge this week.Bullet CC w/ 225 Promax - Sold
STV ProComp w/ 225 Promax
STV Procomp with 280
25 Liberator "The Battleship"
Blazer 650 Pro Tour
08-01-2021, 09:21 PM #2
Yea most gauges take the little brass sender that you drill and tap the head. If you hook to the stock sensor in the head, yeah it will read way hot when it’s really not.
'95 STV "The Blue Goose"
DangerNewb thanked for this postphillnjack liked this post
08-02-2021, 12:55 AM #3
sensor and gauge oem merc?.. real 210 should set off tha buzzer?
08-02-2021, 03:40 AM #46000 RPM
- Aug 2015
- Southeast
- 1,070
- 134
- 80
- 48
- 615
Thank you. That's what I was thinking and hoping. I need to get a water temp sender, drilll and tap, or get a guage designed to read the sender that sits in the head.
The current gauge is a Livorsi water temp gauge hooked up to the sender that sits in the pocket in the head. So they aren't really matched to one another.Bullet CC w/ 225 Promax - Sold
Blazer 650 Pro Tour
08-02-2021, 10:15 AM #56000 RPM
- Aug 2015
- Southeast
- 1,070
- 134
- 80
- 48
- 615
To close this out for anyone else in the same situation, Livorsi says that if you have the 250 degree max temp gauge, they can recalibrate it to work with the dry sender in cylinder head pocket. If you have the 280 max temp gauge, no dice.
Or you can install a water temp sender by drilling and tapping into the head.Last edited by DangerNewb; 08-02-2021 at 10:47 AM.
Blazer 650 Pro Tour
08-03-2021, 09:12 PM #6
You dont need to have a matched sender for livorsi or any other guage. a normal temp sender on the head would work it. but NOT the sender for a buzzer, they go off at totally different temp.. . get a sender from any car shop or ebay they are dirt cheap and only need a single wire up to the dash.....
Head surface temp sender/gauge quesruin
By Brookbbb in forum Technical DiscussionReplies: 11Last Post: 02-17-2017, 12:15 PM -
Left and right cylinder head water temp gauges
By racer7x in forum Electronics, Audio Systems, and WiringReplies: 6Last Post: 09-10-2013, 07:52 PM -
Temp sensor for OMC - water or head temp?
By STV_Keith in forum Technical DiscussionReplies: 6Last Post: 06-12-2006, 11:45 PM -
water temp gauge on head
By bits&pieces in forum Technical DiscussionReplies: 0Last Post: 06-10-2003, 11:48 PM
