Results 1 to 3 of 3
Thread: 2.5L 200 EFI Motor - No Spark
07-31-2021, 10:21 AM #1Junior Member
- Nov 2020
- West Lafayette, IN
Hello All,
I've been fighting this issue for a few weeks now and looking for any input or additional areas to test. Here is a list of all the troubleshooting I have done so far.
Stator test complete
- blue wires measured 185Vdc
- red wires measured 35Vdc
- resistance measurements for each were good as well
Trigger test complete
- each wire to ground measured 1.2-1.3Vdc
- black sleeve to yellow sleeve wires measured 3.8-3.9Vdc
- I did switch out the trigger assembly with a new spare I had from my 2.4 motor and the results were the same, so I switched back
VST is powering on and fuel delivery is good
Power to each coil is measuring 120-125Vdc, and it should be 180-200Vdc. I switched out coils from my 2.4 motor and the results were the same. I knew this step was a long shot, but I was frustrated at this point and wanted to do something.
Switchboxes were both replaced a few hours ago.
Black/Yellow wire to switchboxes measures zero with key off, but measure 1.5Vdc with key on and here is where I have a concern. I believe this should read battery voltage with key on.
07-31-2021, 11:05 AM #25000 RPM
- May 2016
- keys
- 795
- 31
- 45
- 254
- 424
Did you try with black/yellow stripe disconnected? Without checking I want to say that wire is ground when key off, kill in disconnect, or in gear, when in run it should be open circuit. Don't think it's ever positive voltage. Again only about 90% on this.
ANTI40It's just an idea.
rgsauger liked this post
07-31-2021, 08:15 PM #3Junior Member
- Nov 2020
I got the motor running today. I wired the trigger set of wires to the wrong switchbox (my bad on that one). I'm still only getting 145-150Vdc to the coils, so it is smoking really bad. I cleaned all of the ground wires to the coils and tested the resistance and all wires were 0.2-0.4 ohms.
It will run with the black/yellow wires connected, The circuit does go open with the keyswitch on.
I checked the flywheel magnets to make sure they were not loose and didn't find anything unsual.
Spark plug wires Merc 2.5 HP Blue VS Wizard spark plug wires
By MERCURY#1 in forum Technical DiscussionReplies: 12Last Post: 04-02-2020, 07:14 PM -
Mercury Tech: Spark Plugs for MAD EFI System 2.5 260(245)carb motor
By Charger200 in forum Technical DiscussionReplies: 28Last Post: 12-09-2012, 11:00 AM
