Results 1 to 6 of 6
Thread: mercury coils
    Nov 2003
    E.Texas
    mercury coils
    shopping for 300-8M0077471, any descent aftermarket, or best to go pricey oem? thanks.
    I know they are pricey, I go oem. Might try DB electrical, had good luck with their stuff. Never bought coils there tho.
  3. Thanks propshafted thanked for this post
    I think this is the same coil for half the price: https://www.diyautotune.com/product/...ns-and-answers
    From another site:
    • Superseded Part Number:EFI Smart Coil, 300-879984T01 300-8M0077471, 300879984T01 3008M0077471 339879984A1 339879984T00
    • Other Part Number:ign1, IGN-1A, IGN-1, IGN1A
  5. Thanks propshafted thanked for this post
    Nov 2003
    E.Texas
    greatly appreciate info. Looking back can see couple revisions since my stock 03, so they had a good run. Thanks again.
    Jun 2022
    fort worth texas
    I know this post is a yr old but I have a question about the coils. Is there any reference to using this 1-amp coil on an older Optimax 135 which used the 3-wire inductive coil? I realize that the old system used the ECU trigger - cylinder head ground - and Power. The wire would need a sensor ground ( i could pull that from the tps ) - Battery Ground ( pulled from the starter ground). Has this been done or could you foresee a problem?
    DIY Autotune has the same coils without the built-in ignitor... for either inductive or CDI ignitions, if that's what you're after?
    https://www.diyautotune.com/shop/coi...hout-ignitors/
  1. New coils Mercury
    By Bruce2 in forum Technical Discussion
    Last Post: 05-18-2017, 11:30 PM
  2. coils mercury 2.5 efi
    By ddenzin in forum Technical Discussion
    Last Post: 03-07-2003, 09:00 PM
