Results 16 to 22 of 22
08-04-2021, 09:59 AM #16Member
- Jun 2020
- Babylon, NY
- 36
- 16
- 35
Low 80's is the goal plus swinging a small prop to be more efficient, less paddlewheel effect and better handling.
So the part numbers of the case housing between the 150proxs and the 200-275 verado 4.8 are different. But likely due to paint color. I have been able to cross reference carriers and shim sets and other parts and they appear to be identical so that should in theory mean they are essentially the same case
The carrier for example is shared and is 8m0083392 and the housing number i found was 2B026817 for those verados and the 1.85 forward gearset is 892595A05
Getting closer. Ive been in contact with a few very helpful people here on Long Island. Hoping to check the availability and swap these gears out soon.Last edited by OceanMarine; 08-04-2021 at 10:05 AM.
08-04-2021, 11:46 AM #17
Jeff Ziemer has the best balanced Grandsport I know of.
"Confidence" is that wonderful feeling you had right before you fully understood your true situation.- Unknown
I don’t know what effect these men will have upon the enemy, but, by God, they terrify me.- Duke of Wellington“I am not afraid of an Army of lions lead by a sheep; I am afraid of sheep lead by a lion.” – Alexander the Great
Whoever said the pen is mightier than the sword obviously never encountered automatic weapons.-Douglas MacArthur
Allison GSE 300XS
OceanMarine, Ziemer liked this post
08-05-2021, 03:02 PM #18
08-24-2021, 02:07 PM #19Member
- Jun 2020
- Babylon, NY
- 36
- 16
- 35
Just wanted to update this thread in case anybody wants to do this out there. The Verado 4.8 case for 200-275s of the past gear swap does work for the new Mercury 150ProXs four stroke. Thanks to a great local mechanic (Eric) the 1.85's went in without a hitch. Testing the new gears tomorrow and very excited!
JasonRS thanked for this post
08-24-2021, 02:48 PM #20Team Member
- Lake Coochiching, Ontario
- 7,769
- 276
- 487
- 1592
- 6 Post(s)
My brother is thinking of buying the same rig, good info, thanks
OceanMarine liked this post
08-24-2021, 03:28 PM #21
08-24-2021, 03:33 PM #22Member
- Jun 2020
- Babylon, NY
- 36
- 16
- 35
Ill keep you guy posted but i dont think ill have any issues. The stock 150 has 1.92 gears, the Proxs makes at least 5hp more then the regular 150 and supposedly more torque with the spark advance tech it has, so i dont think there should be any issue with the 1.85. I know somebody else did 1.75's without issue. I assume ill gain a couple of MPH hopefully, but even better, now I wont have to swing big props and have a better handling more efficient boat going from a 32 pitch to now able to utilize likely around 28 pitch props.Last edited by OceanMarine; 08-24-2021 at 06:20 PM.
Allison grandsport
By smiley88 in forum Hulls up to 20'Replies: 28Last Post: 12-10-2018, 01:12 PM -
New (to me) Allison GrandSport
By ecpunk in forum General Boating DiscussionReplies: 32Last Post: 10-09-2014, 06:02 PM -
2004 merc 90 hp 2 stroke gear ratio
By fastleeboat in forum Props, Setup, and RiggingReplies: 2Last Post: 05-19-2010, 02:54 PM -
3 Liter Merc Gear Change Question
By Moodgam in forum Technical DiscussionReplies: 4Last Post: 01-09-2006, 08:46 PM
