Results 1 to 15 of 21
    Sep 2011
    omah,ne
    I might have kept my foot in it a little too long.
    I am always amazed how a 2.5 will eat itself up before you even know there is a problem. I felt like the motor was 5 cylindering but it was still pulling to the rev limiter at 7k. Hole shot was a little weak. Made a few passes like this and came back to the beach to find the top corner head bolt loose and a corner of the block chipped in the water jacket head sealing surface. After tear down a day later this is what I found. Crazy how fast water intrusion rusts a steel bore. Just put these heads on a couple weeks ago with new gaskets and correct torque gauge. Ordered head studs for the 260 I am putting together this week for a replacement motor. Wish me luck.
    Attached Thumbnails Attached Thumbnails 20210726_175807.jpg   20210726_175751.jpg   20210726_175746.jpg
  2. Likes Forkin' Crazy liked this post
    Sep 2011
    omah,ne
    One more pic
    Jun 2018
    Merritt Island, FL
    So, what was the root cause of the failure?
  5. Thanks marks86 thanked for this post
    Jun 2018
    Floating around
    Weird one. Can’t say I’ve ever seen a block windowed like that before. Almost looks like water got in the cyl and hydraulic force pushed the block apart while the pistons and rods lived through this? Do you know what happened?
  7. Likes FAST RALLY SPORT liked this post
    Pekin, IL
    5 Post(s)
    I have blown a few up and seen a bunch of them blown up but never like that. When you trash one you don't f**k around. I would love to know what caused that kind of destruction. That's a tuff one.
    Rock
    Team Junk
  9. Likes Capt.Insane-o liked this post
  10. #6
    From the looks of that plastic wire covering on top it got VERY hot.....What temp melts wire coverings?
    83 V-King, Mercury 3.0 back on the transom
    Stop wearing the face bags people. Don't be a sheep!
    May 2016
    keys
    Picture of the heads?
    Looks like head bolt threads went, then gasket, then it was a blow torch across the top of the sleeve.
    ANTI40​It's just an idea.
  12. Likes XstreamVking liked this post
  13. #8
    Ran out of water and melted the head gasket... then the fire melted the sleeve holders away?
    Joke Biden is NOT my potato! .
  14. Likes z1rider, racer, kingsbiship liked this post
  15. #9
    Los Angeles Cal.
    Maybe you are aware of this, when you install new head gaskets it’s a good idea to continually check the torque on the bolts, until they continuously stay at the torque spec.
  16. Likes coffeeguy liked this post
  17. #10
    Houston, TX
    Damn! I've never seen one eaten up like this on the inside.
    If it helps, I'm a certified JB Welder and am in Houston
  18. #11
    Aug 2006
    GA
    Painful
  19. #12
    May 2014
    Livingston, Louisiana
    Dang it man!!
  20. #13
    4 bolts per cyl is not enough especially with open deck. I’d throw that torque wrench in the water and never reuse torque to yield bolts again….
    was the gasket the same? There are thick and thin which will tighten squish. Doesn’t matter what you torque it to if the piston is hitting the head or too close….
  21. #14
  22. Likes rock liked this post
  23. #15
    Los Angeles Cal.
    Correct! You can’t deck the block too many times. Watch that squish. Sometimes you have to recess the heads.
  1. Replies: 9
    Last Post: 02-21-2020, 08:45 PM
  2. Foot throttle and foot trim/or jackplate controller
    By Jim@pamaha.com in forum Misc. Parts and Accessories
    Last Post: 11-24-2015, 08:56 PM
  3. How about this 24 foot long Harley?
    By Robby321 in forum The Scream And Fly Lounge
    Last Post: 10-26-2009, 07:46 PM
  4. foot inches=foot pounds touque wrench?
    By bill mason in forum Technical Discussion
    Last Post: 07-16-2006, 04:49 PM
