Results 1 to 15 of 21
07-28-2021, 11:21 PM #1Member
- Sep 2011
- omah,ne
- 89
I might have kept my foot in it a little too long.
I am always amazed how a 2.5 will eat itself up before you even know there is a problem. I felt like the motor was 5 cylindering but it was still pulling to the rev limiter at 7k. Hole shot was a little weak. Made a few passes like this and came back to the beach to find the top corner head bolt loose and a corner of the block chipped in the water jacket head sealing surface. After tear down a day later this is what I found. Crazy how fast water intrusion rusts a steel bore. Just put these heads on a couple weeks ago with new gaskets and correct torque gauge. Ordered head studs for the 260 I am putting together this week for a replacement motor. Wish me luck.
Forkin' Crazy liked this post
07-28-2021, 11:24 PM #2Member
- Sep 2011
- omah,ne
- 89
One more pic
07-29-2021, 04:37 AM #35000 RPM
- Jun 2018
- Orlando
- 100
- 15
- 9
- 67
- 41
So, what was the root cause of the failure?
marks86 thanked for this post
07-29-2021, 04:50 AM #4
Weird one. Can’t say I’ve ever seen a block windowed like that before. Almost looks like water got in the cyl and hydraulic force pushed the block apart while the pistons and rods lived through this? Do you know what happened?
FAST RALLY SPORT liked this post
07-29-2021, 07:24 AM #5
I have blown a few up and seen a bunch of them blown up but never like that. When you trash one you don't f**k around. I would love to know what caused that kind of destruction. That's a tuff one.
RockTeam Junk
Capt.Insane-o liked this post
07-29-2021, 07:34 AM #6Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
From the looks of that plastic wire covering on top it got VERY hot.....What temp melts wire coverings?
07-29-2021, 08:28 AM #75000 RPM
- May 2016
- keys
- 795
- 31
- 45
- 254
- 424
Picture of the heads?
Looks like head bolt threads went, then gasket, then it was a blow torch across the top of the sleeve.ANTI40It's just an idea.
XstreamVking liked this post
07-29-2021, 09:08 AM #8
Ran out of water and melted the head gasket... then the fire melted the sleeve holders away?
07-29-2021, 09:34 AM #9Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 405
- 3031
- 5318
Maybe you are aware of this, when you install new head gaskets it’s a good idea to continually check the torque on the bolts, until they continuously stay at the torque spec.
coffeeguy liked this post
07-29-2021, 10:53 AM #10
Damn! I've never seen one eaten up like this on the inside.
If it helps, I'm a certified JB Welder and am in Houston1990 Shadow bass boat w/ 2.4 200 Merc. Totally resto'd boat and love it!
07-29-2021, 11:43 AM #115000 RPM
- Aug 2006
- GA
- 855
- 25
- 35
- 71
Painful
07-29-2021, 08:28 PM #12
Dang it man!!
07-29-2021, 10:39 PM #13
4 bolts per cyl is not enough especially with open deck. I’d throw that torque wrench in the water and never reuse torque to yield bolts again….
was the gasket the same? There are thick and thin which will tighten squish. Doesn’t matter what you torque it to if the piston is hitting the head or too close….Last edited by baja200merk; 07-29-2021 at 10:44 PM.
07-30-2021, 08:42 PM #14
rock liked this post
07-30-2021, 09:11 PM #15Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 405
- 3031
- 5318
Correct! You can’t deck the block too many times. Watch that squish. Sometimes you have to recess the heads.
lookin for 81 merc 3.4 drive shaft # 14880T- The long only-NOT xtra long
By MERCMADBOB in forum Parts WantedReplies: 9Last Post: 02-21-2020, 08:45 PM -
Foot throttle and foot trim/or jackplate controller
By Jim@pamaha.com in forum Misc. Parts and AccessoriesReplies: 3Last Post: 11-24-2015, 08:56 PM -
How about this 24 foot long Harley?
By Robby321 in forum The Scream And Fly LoungeReplies: 1Last Post: 10-26-2009, 07:46 PM -
foot inches=foot pounds touque wrench?
By bill mason in forum Technical DiscussionReplies: 6Last Post: 07-16-2006, 04:49 PM
