Results 1 to 15 of 27
    May 2016
    keys
    No start 2.5 efi 200
    Gonna start this thread since I won't get a chance to diagnose the boat for a week at least. Something for us to ruminate on outside the politics section.
    Background. For about a year I've been chasing a Intermittent no start condition. I could never replicate in the shop until recently. I found that my engine side harness had gone bad and voltage was bleeding across the pins. This was acting as a kill switch. I replaced the engine and the boat harnesses. Used the boat a few times with no trouble. Think it's fixed.
    Sunday I put it in for a afternoon cruise. Run a little bit probably less than an hour, I notice the tach is acting funny, bouncing some and seemed to be off by my ear. I can't be sure it was off as I was testing a different prop.
    Stop at the sandbar for maybe an hour or so. Then try to start, just spins. Spinning plenty strong. No coughing no sputtering, just spinning. Pull the cowl, fuel pump runs like it should when key is cycled. I didn't notice a sheen but my buddy that was with me said he could smell fuel while cranking. I very timidly grabbed a plug wire with wet hands standing in saltwater knee deep. I wasn't zapped.
    Went under dash and disconnected kill wire. Still nothing just cranking. Wiggled all the grounds, everything nice and tight. While cranking my tach is reading 3k, I know something's not right. At this point I'm thinking stator is hot and failing. I grabbed a water bottle and sprayed the stator from under the flywheel to see if I could cool it. [Should have gotten water from cooler]. Anyway nothing. I give up and get a tow. Takes a couple hours until it's back in my yard.
    I put the hose to it just to see if I could get some fresh water thru it to rinse. Turn the key. She coughs once fires up perfect second try.
    I'm still leaning toward stator as my first thing to check when I have room in the garage. Will use a heat gun to try and replicate symptoms. Other than that I'll have to open the manual.
    Also trigger is new in the last year.
    200 efi with switchbox ignition no idle stabilizer boxes.
    ANTI40​It's just an idea.
    Florida Keys
    How old is the harness/keyswitch? Try unplugging the cannon plug next time it won’t start and jump it at the solenoid to see if it runs?
    40amp or 16?
    '95 STV "The Blue Goose"
  3. Likes David - WI liked this post
    May 2016
    keys
    Boat Harness, key switch, and engine harness all new. Writing to ecm and related efi still original but look good.
    Didn't think efi would run with cannon plug disconnected. But I've never tried.
    40 amp. Black flywheel. No stabilizer boxes.
    JAX. FLORIDA
    The bouncing tach sounds like a rectifier/harness problem.
    "Confidence" is that wonderful feeling you had right before you fully understood your true situation.- Unknown
    I don’t know what effect these men will have upon the enemy, but, by God, they terrify me.- Duke of Wellington
    “I am not afraid of an Army of lions lead by a sheep; I am afraid of sheep lead by a lion.” – Alexander the Great
    Whoever said the pen is mightier than the sword obviously never encountered automatic weapons.-Douglas MacArthur
    Allison GSE 300XS
  6. Likes David - WI liked this post
    May 2016
    keys
    I'm with you on that. I lost tach signal out of one rectifier a couple years ago and put the grey wire to the other. Been fine ever since. 2 bad rectifiers wouldn't cause no start, not that I'm aware of. I suppose they could hurt the stator
    Charge windings.
    The bouncing was fairy minimal but definitely there. Glitchy might be a better description. It's the tach reading 3k at cranking speed when it wouldn't start that points me at the stator.
    May 2016
    keys
    If it is stator. I really don't need the 40 amps. Only draws I have are the gps and trim. Can't hear the radio while running and plenty boats at the sandbar with monster stereo systems.
    Anybody got a cherry lightweight flywheel there tired of looking at?
    Quote Originally Posted by Whaaaaat View Post
    Depends if the diode fails "open" or "shorted"... you're supposed to check voltage while cranking, I think. https://www.cdielectronics.com/wp-co...th-Edition.pdf
    On p68 or 70 maybe?
    Florida Keys
    go see Ed
  11. Likes Whaaaaat liked this post
    May 2016
    keys
    Yes stock laser injection. I would think 16 amp would keep up. That's how 260 are correct? I could always keep one of those lightweight roll up solar panels on board for when it's resting at the sandbar.
    Florida Keys
    A good charged battery will last all day on a 16amp laser motor as long as you are smart with it.
  14. Likes Forkin' Crazy liked this post
    Anybody know what rpm they actually hit the rated amps at... 16 or 40-amp; they don't make that at idle?
  16. #12
    May 2016
    keys
    Had a chance to look at it today. Tearing my hair out.
    Started fine in the morning and ran on the hose for 30 minutes. Shut it down took a break found an umbrella( felt like a 100 today no wind)
    Tested after about 15 minutes. No start.
    I think great its finally broken where i have tools. I put spark gap tester on it. Spark on #3 intermittent on #2 even less intermittent on #1. I'm lost now this makes no sense. Out comes the DVA and meters.
    Voltage and ohms test good on stator.
    Ohms test good on trigger. cdi has a spec to test 2 wires for voltage from trigger. Spec is 4volts. I have 1.5volts. Each lead from trigger to ground is .5 volts. Mercury specs 1-4 at cranking. Can a trigger be weak and not dead?
    Swapped 1 switch box for used spare with no change.
    Swapped flywheel with used spare no change.
    Boxes ohm 14.1k on bias to case.
    Test for voltage at kill post on boxes was way low. Mercury wants 200volt. I have 4volts.
    I either have a bad 10 hour old trigger or 3 bad switch boxes.
    I'm going to double check some things tomorrow before it gets 100 degrees outside.
    Aug 2020
    Dickson, Tennessee
    *copied from archives*
    all tests need to be done with a DVA
    the DVA will let you read AC volts on a dc scale without the voltage jumping all over the place
    The trigger voltage with a DVA should read 4 v at cranking speed
    across the 2 corrosponding wires
    ( the same wires you would do the resistance test on)
    When testing the trigger ...grounding the meter lead will not help you at all because the trigger is not grounded to anything its emitting AC volts!
    the trigger trips a SCR in the switch box when the AC volts are +
    the trigger is connected to cyls 1+4...2+5....3+6
    when + voltage is applied to #1 post on the switch box #1 coil will fire
    #4 switch box post gets negative voltage which does not trip the SCR but gets re directed to the charge capacitor and gets stored as negative voltage to be stored until the coil fires
    when the voltage flips + voltage goes to #4 and trips that SCR and fires that coil #1 post gets negative voltage and redirects the negative voltage to the charge capaciter.
    All the switch box inputs are ACvolts
    the out puts are DC volts
    Test Bias circuit
    DVA red wire to ground
    DVA black wire to WHT/BLK
    1-6v@cranking speed
    Test stop circuit
    DVA red to BLK/YEL
    DVA black to ground
    200-400 v @ cranking speed
    test High speed stator
    DVA red to red/wht stator wire
    DVA blk to ground
    25-50 v@ cranking speed
    Test Stator low speed
    DVA red to blu/wht stator wire
    DVA blk to ground
    100-265 v @ cranking speed
    test for coil
    DVA red to coil+
    DVA blk to coil-
    90-145 @ cranking speed
    if the trigger test is ok and the bias test fails its the switchboxes
    if the trigger test is good and the stop circuit test fails its the switch boxes
    Maybe this will help.
  18. #14
    I have had intermittent triggers before. Run fine, shut down and re-start after a while would lose fire on 3 cyls.
    May 2016
    keys
    Everything passes mercury test procedures. Next step replace switch boxes and test again.
    Trigger passes mercury test. Low voltage according to cdi test procedures.
    Going to replace all 3
    Will blue racing boxes work on 40amp system, and are they worth the extra$ ? Difference not that much.
  1. mercruiser230 no start with ignition in start position
    By chriscraft291 in forum Technical Discussion
    Last Post: 04-08-2013, 02:27 PM
  2. Yamaha Tech: Question about adding recoil start on an electric start 9.9 Yamaha - can it be done?
    By Steve2ManyBoats in forum Technical Discussion
    Last Post: 09-11-2012, 06:12 AM
  3. no start
    By davmor in forum Technical Discussion
    Last Post: 08-30-2011, 06:21 PM
  4. Let's See where do I Start.
    By thaw ripper in forum Fiberglass and Composites Discussion
    Last Post: 05-31-2007, 01:58 AM
  5. What biz to start with 60K ?
    By neveredge in forum The Scream And Fly Lounge
    Last Post: 09-26-2005, 06:48 PM
