Results 1 to 9 of 9
Thread: Small Light Boat Battery
07-26-2021, 12:11 PM #1Member
- Apr 2021
- Colorado
- 51
I'm looking for a good choice on this to save weight and space. Don't run stereos, fish finders etc, just starting and running.
Any suggestions?
Seems like a jet ski battery would be best. Engine: Merc 225 bridgeport 2 stroke
07-26-2021, 02:47 PM #26000 RPM
- May 2001
- Madison, WI
- 1,147
- 253
- 39
- 499
- 198
I'm running a East Penn DEKA AGM 16L. 16-17 lbs. They are also private labeled and sold everywhere under a wide variety of "house brand" names.
Its an interesting story
You can find all the specs on East Penn's website.
The CCA and Reserve times are conservative. I put mine it a small ammo box and put one of those little DC Volt meters on top of the box to keep an eye on it. It has worked amazingly well for me and has saved me 20-30 lbs of transom weight.Last edited by scott reierson; 07-25-2022 at 01:14 PM.
rgsauger liked this post
07-26-2021, 02:57 PM #3Member
- Apr 2021
- Colorado
- 51
Thank you for this information.
I'm rebuilding the area of the boat where the battery goes so I need a good design. Right now there are some "firing strips" that form a big box. I'm thinking of getting rid of all this and just going to a hold down base. Didn't find too much on the web but I did find this 3D printed version. MIght be able to design a better one
07-26-2021, 03:10 PM #4Screaming And Flying!
- Jan 2004
- Los Angeles Cal.
- 4,831
- 405
- 3031
- 5316
I’ve run these type of batteries for years on a 2.5 16 amp charging system.
The odyssey PC 625 weight is somewhere around 11 pounds. The bat cap is somewhere around 9 pounds. I have a standard size plastic battery holder with a high density foam all around the battery to reduce vibration it’s also extremely light.
07-26-2021, 04:35 PM #5
I use the series 51 battery. A standard automotive battery that goes in Accord/Camry. Only weighs 26 lbs. You get an automotive warranty.
It is top post battery so just install the marine adapters. Plenty of CCA and reserve. Been using them on v6 Mercs for yearsdeath is certain; life is not
scott reierson, rgsauger thanked for this postphillnjack liked this post
07-27-2021, 06:38 AM #6Member
- Jul 2015
- paloaltl ca.
- 33
I run a 5 lbs. Shorai in my 2018 xr2002 with a con. 280
07-27-2021, 07:06 AM #7Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
Antigravity 30 cell if you want to go lithium. Should be in the 5-5.5 lb range
Erik Kiser
07-27-2021, 10:18 AM #86000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
I RUN a batt-tender lith 2.5 lbs. cranks my2.5 pm no problem
07-27-2021, 10:45 PM #9
Light weight battery
By Esox4130 in forum General Boating DiscussionReplies: 18Last Post: 10-25-2017, 06:07 PM -
light weight battery?
By J.R. in forum Technical DiscussionReplies: 43Last Post: 05-14-2016, 01:09 PM -
Light weight battery options.
By MUDSHARK in forum Technical DiscussionReplies: 25Last Post: 05-14-2015, 08:34 PM -
My custom polycarbonate battery box for light weight drag battery.
By Mitchie in forum General Boating DiscussionReplies: 4Last Post: 06-04-2013, 07:39 AM -
Do PVS plugs even matter on a light boat with small hub / large gearcase?
By Ron V in forum Technical DiscussionReplies: 1Last Post: 07-10-2010, 09:44 PM
