Results 1 to 11 of 11
    Jun 2018
    Floating around
    Anyone got pics of a 225 Promax Chest?
    Trying to compare and see whats different to the FF, especially the dump holes from inside the chest looking down and the bottom side looking up would be of great help
    Jun 2009
    Bristol, Connecticut
    Subscribing
  3. Likes Scream And Fly liked this post
    Jun 2018
    Floating around
    Heres a 260 base over the FF, looks to be identical to my promarine 200HP gasket size which is what I was using
    shreveport,la
    The exhaust chest will have hardly any difference. I’m pretty sure the biggest difference in the Promax and the 200 is in the transfer ports
    Erik Kiser
  6. Likes LakeFever, Capt.Insane-o, tux974 liked this post
    Jun 2018
    Floating around
    I measured the exhaust port height its the same as a ProMax 1.62"
    The reason im asking is I an going to run a promax 225 ECU so I want to get the block as close as possible and in previous threads here irt was made clear the main difference in the 225 Promax was the exhaust chest and block exit. I have seen plenty of pics of the exhaust ports and measured mine to compare and they look very similar if not the same. If the dump is a choke I'll open it up but if it is the same as the FF? I'll leave it
    Its mighty tricky to know without having all these blocks sitting side by side. First time anyone mentioned transfer port differences. I'll keep posting and updating, we'll get er figured. Thanks Patches
    Waretown, NJ
    This is a stock 225 promax exhaust.
  9. Thanks LakeFever thanked for this post
    Sep 2008
    louisville
    Here is a brand new 2020 block
    Here is a new block
    Attached Thumbnails Attached Thumbnails CBE6ADCB-0149-455E-8FFC-9B75FD3166C5.png
  11. Thanks LakeFever thanked for this post
    Likes LakeFever, Capt.Insane-o liked this post
  12. #8
    Jun 2018
    Floating around
    You guys rock! I don’t suppose you have any pics looking up into the exit? Where it would meet the plate? Or even better a length/width measurement of one of the holes exiting the block
  13. #9
    Waretown, NJ
    This measures 2.145 tall 1.450 wide
  14. Thanks LakeFever thanked for this post
    Likes LakeFever liked this post
  15. #10
    Jun 2018
    Floating around
    Excellent help thank you! One more thing im curious about, if you drop a scale straight edge down in the chest running accross the bottom of the grooves there does the bottom port touch the scale or is that section lower than the top two?
    For reference heres the FF exhaust dumps taken at as close as I could to your angle for reference. You can see it looks like its only the dump ramp thats different. If I place a straight edge in the valley of the notches it touches perfectly the top of the ramp on the FF dump so I suspect it will be 3/8" or so above the Promax dump ramp. I might post a pic of the straight edge so it makes sense. The FF Dump holes measure 1.75" x 1.45"
  16. #11
    Jun 2018
    Floating around
    The even side ( holes 2,4 ,6 ) is on the left and the straight edge rides right in the valley of the notches and sits on top of the ledge pretty dang close to perfect. The odd side however the ridge of the ramp is slightly taller than the bottom of the valley.
    Attachment 491082Attachment 491083
  1. ISO 260 or promax Exhaust Chest divider
    By spongebob440 in forum Misc. Parts and Accessories
    Last Post: 03-25-2018, 09:16 PM
  2. Did you just look at my chest?
    By head_dunce in forum The Scream And Fly Lounge
    Last Post: 01-03-2012, 10:23 PM
  3. Merc Promax controlled by Cummins???!!! (pics)
    By silverbullet02 in forum Technical Discussion
    Last Post: 09-13-2010, 05:45 AM
  4. Mercury Tech: 225 ProMax chest question
    By TheRickster in forum Technical Discussion
    Last Post: 08-13-2008, 05:10 PM
