Results 1 to 7 of 7
    Mar 2021
    Mb
    Timing 1999 Efi 150
    Pulled cover off. Says to unhook white lead to stabilizing box. Then time to 15 degrees at cranking speed, and should be 16 degrees at 5000rpm. I run 87 fuel,best we have in Canada is 91. Where should I time it to, it has not been touched still has silicone on adjusters.
    Houston, TX
    Mercury?
    welcome to scream and fly
    Mar 2021
    Mb
    Yep
    When setting static timing disconnect white/blk bullet connector at idle stabilizer and disconnect ECU.
    Mar 2021
    Mb
    Dave, do you set timing to factory or do you advance a little bit more?
    Quote Originally Posted by Apex2007 View Post
    Static settings factory spec. Use pickup timinv to set idle speex in water.
    Mar 2021
    Mb
    Thanks
  1. Replies: 19
    Last Post: 09-09-2015, 07:56 PM
  2. 1999 merc 200 efi timing pointer (confused)
    By firedaddysc in forum Technical Discussion
    Last Post: 02-13-2014, 06:19 PM
  3. Mercury Tech: Interchange Trim unit between 1999 225 EFI and 1999 225 OPTI
    By javiert99 in forum Technical Discussion
    Last Post: 11-12-2013, 09:44 AM
  4. 1999 XR6 150 or 1999 Optimax 150
    By EMC 2870 in forum General Boating Discussion
    Last Post: 07-31-2013, 08:39 AM
