Results 1 to 7 of 7
Thread: Timing 1999 Efi 150
07-24-2021, 02:29 PM #1Member
- Mar 2021
- Mb
- 36
Timing 1999 Efi 150
Pulled cover off. Says to unhook white lead to stabilizing box. Then time to 15 degrees at cranking speed, and should be 16 degrees at 5000rpm. I run 87 fuel,best we have in Canada is 91. Where should I time it to, it has not been touched still has silicone on adjusters.
07-24-2021, 04:52 PM #2
Mercury?
welcome to scream and fly1990 Shadow bass boat w/ 2.4 200 Merc. Totally resto'd boat and love it!
07-24-2021, 07:33 PM #3Member
- Mar 2021
- Mb
- 36
Yep
07-25-2021, 11:16 AM #4
When setting static timing disconnect white/blk bullet connector at idle stabilizer and disconnect ECU.
07-25-2021, 11:20 AM #5Member
- Mar 2021
- Mb
- 36
Dave, do you set timing to factory or do you advance a little bit more?
07-25-2021, 01:06 PM #6
07-25-2021, 03:24 PM #7Member
- Mar 2021
- Mb
- 36
Thanks
Setting timing using a 16 amp lightweight flywheel with no timing marks
By jdewaard in forum Technical DiscussionReplies: 19Last Post: 09-09-2015, 07:56 PM -
1999 merc 200 efi timing pointer (confused)
By firedaddysc in forum Technical DiscussionReplies: 3Last Post: 02-13-2014, 06:19 PM -
Mercury Tech: Interchange Trim unit between 1999 225 EFI and 1999 225 OPTI
By javiert99 in forum Technical DiscussionReplies: 2Last Post: 11-12-2013, 09:44 AM -
1999 XR6 150 or 1999 Optimax 150
By EMC 2870 in forum General Boating DiscussionReplies: 4Last Post: 07-31-2013, 08:39 AM
